Body Lift Question
Old Oct 24, 2011 | 10:28 AM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Default Body Lift Question
Well I want to do a 2'' body lift, but when I took off one of the frame bolts to remove nerf bars it snapped, now what?
Old Oct 24, 2011 | 10:43 AM
warthogdriver's Avatar
your gonna have to drill it out.
either from outside or inside.
i think the inside you will need to cut the body to get access and then drill it, then put in a longer bolt with a nut if you cant save the square nut that is attached to the body.
just what i would do if it happened to me...others will chime in, i am sure.
Old Oct 24, 2011 | 10:48 AM
gatorboy44's Avatar
Pheww sounds like a royal pain!
How did you do it?
Old Nov 4, 2011 | 07:59 PM
gatorboy44's Avatar
^Bump
Old Nov 5, 2011 | 08:07 PM
SLE_MuNkY's Avatar
SLE_MuNkY is on a distinguished road
Is any of the bolt still sticking out? Do you have a welder?
If you can get a nut to grab even just a thread or two, you can then weld the nut to the end of the bolt remains, then back it out.
Old Nov 5, 2011 | 09:26 PM
gatorboy44's Avatar
Ya know, as simple as that is I didn't think of that, I'll try that! Thanks!!
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
