body lift suggestions
Old May 3, 2010 | 03:06 PM
clw97bravada's Avatar
clw97bravada is on a distinguished road
I bought a 97 bravada and am reaching its limits off road. I tweaked the torsion bars an inch and made a set of 2" shackles. Thinkin bout gettin a body lift and 31s. I have noticed not many people did the 3" body lift. Is there a reason for it? I can get either for the same price.
also id love to see pics of a blazer, bravada, or jimmy with a similar set up or body lifts only.
Last edited by swartlkk; May 3, 2010 at 08:23 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 3, 2010 | 03:13 PM
Benedict1337's Avatar
It is because the 3" body lift is only made for the first generations. Everything is pretty much the same other than the bumper mounts are different so you would have to make your own if you buy the 3" body lift. I would probably be easier to just get the 2 in body lift made for the second generations. then that way everything would be a direct fit. even with a 2" body lift you will have plenty of room to put 31's. I have the tbars cranked and shackles and I'm running 31's
Old May 3, 2010 | 04:03 PM
I found this one on amazon for a 98 to 03. Don't know if it will fit on a 97 though. Hopefully someone can get use from it.
http://www.amazon.com/Performance-Ac.../dp/B0006PXYCK
Old May 3, 2010 | 04:36 PM
I was reading it says "Body Lift Kit; 2 in. Lift; Incl. Front/Rear Bumper Brackets; | Veh. w/Vortec V6 May Require Modification Of Air Intake Or Air Intake Hose~ Rear Bumper Brackets Enhance Appearance Only: Bumper Cannot Be Used To Tow~ ZR-2 Model Requires Modification To Steering Column Mounting Flange~ Gap Guards Available And Sold Separatel" not sure what modifications it is all talking about and notice how it says 2 inch body lift. I don't know if I would trust this
Old Oct 13, 2010 | 05:01 PM
iamchevyman5's Avatar
iamchevyman5 is an unknown quantity at this point
How did you make your own shackles?
They're online for $50, but I'm an engineering student at Western Michigan University and have training and access to CAD software and machining stuff. Can I use this to make my own? Let me know!
THanks,
Dan
95blazerlt
Sep 1, 2013 10:30 PM
RedNeckWagon360
Apr 3, 2009 11:53 AM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
billthegoat
Oct 16, 2006 11:32 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
