Body and Suspension lift
Old Mar 20, 2010 | 06:29 PM
ldzisme's Avatar
ldzisme is an unknown quantity at this point
Default Body and Suspension lift
Hey Guys, I was planning on putting the rough country 2" suspension lift and a 2 inch body lift on my 2000 four door blazer. I just had a few questions, would i run into any problems with this combo, also what rim and tire setup would you guys recommend for little to no trimming. My blazer is gold/champagne so what rim style would you recommend as well. Thanks in advance guys.
Old Mar 20, 2010 | 09:36 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
with that set up you should go with 31x10.50 tires as it will fit with no rubbing and trimming. as far as wheels goes i'm not sure how black rims would look on it, i guess you should check out some blazers around here find a style that fits what you like cause it is your blazer.
Old Mar 20, 2010 | 09:44 PM
NVANZEE's Avatar
like he said you will be fine with 31s on stock rims. If you go with aftermarket rims you will want 6in backspacing. If you have less backspacing you wont be able to fit as big of tires with out some minor trimming. Also i wouldn't waste the money on a 2in suspension lift. You can do it your self for 60 bucks. Get a good set of shackles for the rear. For the front you can crank the tbars 1.5in. Do a search and you will find info on how to do those things. Its cheaper and easier for the same exact thing.
Old Mar 20, 2010 | 11:02 PM
bandidolenny's Avatar
I would skip the 2" suspension lift and just do a T-bar crank.
With a 2" suspension lift and a 2" body lift (and fender trimming)... I am running 31x10.50-15 BFG AT's on 10" wide wheels with 5.5" backspacing with no issues.
Old Mar 20, 2010 | 11:35 PM
ldzisme's Avatar
thanks for the help guys. Im just curious how much bigger does the blazer look with this type of setup. my blazer is stock height right now with cooper discoverer atr's. I just want my ride to look beefier and preform better offroad thanks
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
