Cant get shackle bolts out
Old 02-21-2008, 08:27 AM
motoraser125's Avatar
motoraser125 is an unknown quantity at this point
Default Cant get shackle bolts out
I started putting the lift onand I cant get the bolts out of the rear shackles. Any ideas? I would post picks but my camera broke.
Old 02-21-2008, 08:33 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Cant get shackle bolts out
Lots of PB Blaster. Spray 'em down really good.
Get a wrench (longest one you have)on them and push/pull back and forth to work them loose. It takes a bit of muscle and even more patience, but you'll be able to get them out.
Old 02-21-2008, 08:35 AM
95BlazerLt4wd is an unknown quantity at this point
did you get the nuts off the bolts? if not drench them with PB Blaster, let it sit for 5-10 minutes then go at it again. If the nuts are off, hit the bolt with a hammer and onceyou cant hit the bolt anymore,take a punch, if not available a screwdriver of some sort, and keep hammering it through.
EDIT: ahh, you beat me to it lol.
Old 02-21-2008, 09:03 AM
I will have to go get some of that PB blaster stuff and give that a shot because this WD40 is working too well. I dont have much room to hit it hard with a hammer either.Thenut is already off I just cant getthe boltout.
Old 02-21-2008, 09:14 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
are you sure you have tension off the bolt in the shackle????
Old 02-21-2008, 10:35 AM
Zasder is an unknown quantity at this point
If you take off the bumper and the side fenders, you will have ease access to the bolts.
Old 02-21-2008, 02:30 PM
jphayes921 is an unknown quantity at this point
if you cant get the bolts out just get new leaf bushings and cut the old bushings out. thats what I had to do. luckly i had some Xj bushings that fit right in from a lift I put on a the XJ.
Old 02-21-2008, 02:56 PM
you shouldnt need to hit it that hard to get it out, i mean you dont need to reallly beat on it. especially on a 02 blazer it shouldnt be very rusty.
Old 02-21-2008, 03:06 PM
Jigg's Avatar
When i did mine... they were a pain to get loose. They don't come out as easy as you'd think.
Old 02-21-2008, 03:19 PM
navyblue_sk8er is an unknown quantity at this point
I had to use a huge C-clamp to press out the bolts. Big pain in the butt rusted in bolts are.
Quick Reply: Cant get shackle bolts out
