Cant get shackle bolts out
Old Feb 21, 2008 | 08:27 AM
motoraser125's Avatar
motoraser125 is an unknown quantity at this point
Default Cant get shackle bolts out
I started putting the lift onand I cant get the bolts out of the rear shackles. Any ideas? I would post picks but my camera broke.
Old Feb 21, 2008 | 08:33 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Cant get shackle bolts out
Lots of PB Blaster. Spray 'em down really good.
Get a wrench (longest one you have)on them and push/pull back and forth to work them loose. It takes a bit of muscle and even more patience, but you'll be able to get them out.
Old Feb 21, 2008 | 08:35 AM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
did you get the nuts off the bolts? if not drench them with PB Blaster, let it sit for 5-10 minutes then go at it again. If the nuts are off, hit the bolt with a hammer and onceyou cant hit the bolt anymore,take a punch, if not available a screwdriver of some sort, and keep hammering it through.
EDIT: ahh, you beat me to it lol.
Old Feb 21, 2008 | 09:03 AM
I will have to go get some of that PB blaster stuff and give that a shot because this WD40 is working too well. I dont have much room to hit it hard with a hammer either.Thenut is already off I just cant getthe boltout.
Old Feb 21, 2008 | 09:14 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
are you sure you have tension off the bolt in the shackle????
Old Feb 21, 2008 | 10:35 AM
Zasder's Avatar
Zasder is an unknown quantity at this point
If you take off the bumper and the side fenders, you will have ease access to the bolts.
Old Feb 21, 2008 | 02:30 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
if you cant get the bolts out just get new leaf bushings and cut the old bushings out. thats what I had to do. luckly i had some Xj bushings that fit right in from a lift I put on a the XJ.
Old Feb 21, 2008 | 02:56 PM
you shouldnt need to hit it that hard to get it out, i mean you dont need to reallly beat on it. especially on a 02 blazer it shouldnt be very rusty.
Old Feb 21, 2008 | 03:06 PM
Jigg's Avatar
When i did mine... they were a pain to get loose. They don't come out as easy as you'd think.
Old Feb 21, 2008 | 03:19 PM
navyblue_sk8er's Avatar
navyblue_sk8er is an unknown quantity at this point
I had to use a huge C-clamp to press out the bolts. Big pain in the butt rusted in bolts are.
