Drop Pitman Arm
Old Jan 24, 2012 | 09:50 PM
xachman17's Avatar
xachman17 is on a distinguished road
Default Drop Pitman Arm
Where can i find a drop pitman arm for a 2" lift on a ZR2? i have looked everywhere and no luck
Old Jan 25, 2012 | 12:17 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
u can use a xj pitman arm too. same splines.
Old Jan 25, 2012 | 09:03 AM
xachman17's Avatar
thanks man i didnt know that
Old Jan 27, 2012 | 10:36 PM
skotti's Avatar
skotti will become famous soon enough
why do u need a drop pitman for 2" lift? 2" sounds like its still ifs, and in that case use oem replacement.
A drop pitman arm will not work if its stock ifs.
Old Jan 28, 2012 | 12:36 AM
neo71665's Avatar
It will work you just don't need one with an ifs. Prolly only make the idler arm wear out faster than they do now on these trucks.
Old Jan 28, 2012 | 08:31 AM
skotti's Avatar
stock pitman arm has the tie rod end built in. any drop pitman does not.
he would have to make a custom drag link, one end would have to have the tapered hole for idler arm. the other end would need a threaded insert to accept a tie rod end. then even further this drag link would still need to accept oem tie rod ends.
Note even if u did manage to do all this, the new angle would destroy both idler and tie rod end very very quickly.
so yes a drop pitman from a xj will bolt onto our steering box...will it work for ifs...no
Old Jan 29, 2012 | 09:28 AM
xachman17's Avatar
so a oem replacement will tighten my steering back up?
Old Jan 29, 2012 | 09:46 AM
xachman17's Avatar
it is still stock except for the 2" torsion keys i installed
Old Jan 29, 2012 | 03:08 PM
duxtoyz's Avatar
replacing the bushings on ur stock arm or replacing the arm would tighten ur steering up. putting a drop arm on an ifs rig wouldnt benefit u any. just replace urs with a stock oem one and grease it and u should be fine.
Old Jan 29, 2012 | 09:42 PM
xachman17's Avatar
okay, makes sense. thanks alot
