First post + noob question.
Old Jun 13, 2011 | 08:00 AM
twisted125's Avatar
twisted125 is on a distinguished road
Question First post + noob question.
New to the forum, looks like an awesome place for some good info and conversation. I just get a new to me 01 4dr 4wd for a slammin deal and got out of my truck note at the same time. Im stoked to finally be in another 4 wheel drive and want to start to get some height on it. I noticed that my drivers side front tire inside tread pattern is near bald. That coupled with a slightly cocked steering wheel and slight pull to the right hints toward alignment time. Before I take it in, I am going to do the Tbar crank. I figure if I can do that today or tomorrow, then I can get it in for an alignment soon after, a required function after the crank. I will put a set of shackles on order so hopefully they will show up to follow the alignment.
Questions -
1. Would you re-align after shackles or only after Tbar Crank?
2. I see all kinds of different shackles. I could but dont really have time to make a set myself. Full time and starting a business on the side keeps me pretty busy. So, whats a good set?? I have seen guys on here making and selling, are they still doing this??
Old Jun 13, 2011 | 08:10 AM
I would do it all at once (t-bar crank & shackles) then get the alignment, but the t-bar crank has much more of an impact on alignment. Just don't go too far with the t-bar crank.
I suggest you get to the bottom of why the tires wore like they did before getting an alignment. Check out all of the suspension components (bushings, inner/outer tie rods, pitman/idler arms, etc before you go in just to make sure that there isn't something worn that caused the problem in the first place.
Old Jun 13, 2011 | 08:19 AM
twisted125's Avatar
Roger that, thanks! On the subject of Shackles, is there anyone around here making a solid set for a good price or should I head to Ebay??
Judging by the front end of the Blazer, it was definately popped in the mouth at some point in its life. Cracked headlight mounts (bouncy) , slightly dipped front bumper, non oem hood, etc. Its in really nice shape and drives really well though. (SOOOOOOO much nicer than my full size truck.) I can actually negotiate drive thrus!!! The small stuff I can take care of. Ill get under her and check it out closer. Tie rod and others would make sense to look at.
Thanks again Swart
Old Jun 14, 2011 | 06:48 PM
twisted125's Avatar
bump bump bump
Old Jun 14, 2011 | 07:58 PM
RangerG's Avatar
Ebay or SynergyOffroad
Old Jun 15, 2011 | 08:05 AM
twisted125's Avatar
Thanks Ranger
Old Jun 15, 2011 | 12:11 PM
Rottidog's Avatar
Just keep in mind that "2" shackles only = 1" of lift in the rear because you're only lifting half the leaf spring.
Old Jun 15, 2011 | 03:11 PM
twisted125's Avatar
Thats what everyone is using for the most part right? 2" shackles and Tbar crank? I'll body lift later on.
TS2GFrank
May 9, 2020 05:12 PM
apo02
Dec 13, 2012 03:58 AM
bill9000
Headers, Intake, & Exhaust
Dec 23, 2010 07:58 PM
mysssticghost
Dec 17, 2007 08:10 PM
