fitting 32"
Old Apr 5, 2011 | 03:42 PM
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
I think it depends on the tread style also. I think with some AT`s you`ll be fine...
EDIT: I just forgot that i put them on before the bodylift...
Old Apr 5, 2011 | 06:53 PM
pbrubaker12's Avatar
pbrubaker12 is on a distinguished road
I have the 1.5" tbar crank with 2" rear shackles on an '01 and I'm running 31s (30.5") without rubbing unless there's some flex so you'll definitely have some to do some trimming but I wouldn't expect too much
I ended up taking my front bumper off for the time being so there's plenty of room for my tires now haha
Old Apr 5, 2011 | 09:04 PM
rgdpuddin's Avatar
rgdpuddin is on a distinguished road
im just gonna go for it 32x11.50r15 on some soft 8's 15x10 ill remove whats in the way lol
Old Apr 5, 2011 | 10:07 PM
Benedict1337's Avatar
you'd probably have less problems with 15x8's
Old Apr 6, 2011 | 01:09 AM
yea I would suggest 15x8s as well...
Maybe you can correct me on this Benedict but I think you might rub the control arms with a wider wheel?
Old Apr 6, 2011 | 12:13 PM
Rottidog's Avatar
That depends on the offset, how far the tire/rim sticks out. That being said, the further you go out the more likely you are to have rubbing issues with the bumper & fender.
Old May 6, 2011 | 11:19 AM
sharrard.'s Avatar
sharrard. is on a distinguished road
dude theres no way it wont fit i have a two inch and fit 31s no problem
Old May 12, 2011 | 10:53 AM
carlosblazer's Avatar
carlosblazer is on a distinguished road
RGDPUDDIN, there are plenty of possibilities, i had a 1988 s10 blazer and crank the torsion bars an put rear shackles, then put 31īs on it, an it rub a lot, then i put a PA 3 inch body lift and the problem is over, now i have a 1998 s10 blazer and crank the t-bars and add lift shackles at the back and 31īs run ok, iīm thinking of buying a 2" body lift and put 32īs on it, i hope they donīt rub. can you put pics to see your truck with 32īs? hope they donīt rub in your blazer, if they donīt iīll copy your idea
Old May 13, 2011 | 06:27 PM
rgdpuddin's Avatar
hey guys just an update i decided to run 31's for now on 15x8 rims with a 4" back spacing went with a t bar crank runs awesome no rubbing at all and i don't even have shackles in yet looks kinda stupid but w/e ill get to it (after i hacked off some fender and bumper haha) here is a picture of the beast next to come is a 2" body lift and the set of 32x10.5 i have sitting in the garage
Old May 13, 2011 | 10:16 PM
31's will fit stock in the rear since rear tires don't turn. you may still have to do some trimming with the 32's and the body lift. and 15x10's won't rub the control arms but just about everything else... I wouldn't get 15x10's unless you are going 33's or bigger, but by that point your only option is pretty much a solid axle swap. Jimmy looks good thou those american racing wheels?
