Front swaybar disconnect
Old Apr 21, 2010 | 01:26 AM
cyberdog's Avatar
cyberdog is on a distinguished road
Default Front swaybar disconnect
DOes anyone have a howto or pics of how to make a front swaybar quick disconnect ?
Thx
Old Apr 21, 2010 | 11:15 AM
dougg01's Avatar
dougg01 is on a distinguished road
do a web search on 'ZR2 sway bar disconnect'. Lots of articles.
Basically get a grade 8 3/8 bolt, wing nut, and a hairpin clip. Drill a hole in the bolt just past where the wing nut will tighten the bushings. The hole is for the clip to prevent the wing nut from backing off. Glue bushings to washers after welding center shank to center washers. This helps keep you from chasing after parts.
Old Apr 23, 2010 | 11:37 AM
cyberdog's Avatar
Hmm are u sure about the 3/8 bolt ? I read in a few places that it uses a 3/8 bolt but i meassured mine and its 0.33 inches . 3/8 is more like 0.37 inches. Maybe the bushings has room for a 3/8 but havent been able to remove mine yet
Old Apr 23, 2010 | 11:42 AM
The factory stuff is likely M8 hardware 8mm = 0.317".
The holes through the lower control arm and the sway bar should be large enough to support a 3/8" bolt and you can enlarge the rest of the stuff to make that work as well.
Not only will it be stronger, but the bolt will be easier to find.
Old Apr 23, 2010 | 01:25 PM
Benedict1337's Avatar
how bad would the handling be if you disconnected the front sway bar completely?
Old Apr 23, 2010 | 03:20 PM
There would be nothing counteracting body roll... It wouldn't be too fun.
Old Apr 23, 2010 | 03:27 PM
oktain's Avatar
I remember watching Trucks as a kid... he built up an old ****** panel truck and didn't put sway bars on it and he almost rolled it on an interstate on ramp.
Old Apr 23, 2010 | 06:25 PM
jdespain's Avatar
It would be one heck of a scary ride.
Old Apr 23, 2010 | 07:54 PM
AJBert's Avatar
I ran without my front sway bar for about a year due to a bent mounting bracket that I was too lazy to fix. The ride wasn't too terrible as long as you don't drive like a teenager. But I finally got off my butt, straightened the bracket and put the bar back on. Tightened up the front end quite a bit!
But a great mod for offroad!
Old Apr 26, 2010 | 12:11 PM
dougg01's Avatar
http://s20.photobucket.com/albums/b2...20Disco%20mod/
Picks.....
Again...search on ZR2, disconnect, and sway bar. Plenty of links.
Oh, and stock bushings suck. The 3/8 is for use with the ES bushing kit.
