Getting High
Old Apr 17, 2020 | 11:23 AM
Heftynoma's Avatar
Heftynoma is on a distinguished road
Soo once upon a time I bought a blazer and it was awful. Beat to poop had like 10 lbs of oil pressure max. So I Sold it to my dumb sister for over double what I paid.
A couple years later I got a super clean Sonoma It was my dd and wheeling toy. I ended up destroying cv’s, bj’s, hubs, and crashed into a pole. So I went out and got a pair of 79 f250 axles 44/60 combo, with flat tops. Got junk yard Dakota springs, ranger spring hangers and I am still acquiring parts. So far I’ve got my front crossmember mounted and the og one cut out. Front spring pack together and cut out the hump on the driver side of the frame to make it look like the other side. Now for pictures.
Did some work tonight got the hangers tacked in place. And I started to get the old perches off my 60
so I got some stuff done as you’ll see. Got the truck on the wheels. Shackle angle is iffy. Might wanna bring them a little forwards.
Ground to bottom of frame 18.5 with 27” tires. Not bad.
Update. So I cut my shackle mounts off and moved them like 2 or so inches forwards. In the process I have to cut my exhaust. No biggie
Ended up with 30 degree shackle angle
Neither of these shackle pics have weight on the truck.
Cut the chin spoiler off my bumper and threw it in to see what it’s gonna look like.
These are stock 8 lug Steelies and they stick out just a little bit lol.
Got a bunch of parts in. Still waiting on a few things tho.
Last piece of the puzzle.
UPDATE. Welded on my rear perches and set my pinion angle.
U bolt eliminators almost done.
Full droop. Replacing all brake parts
Took abs bull poop off and got a regular disk/drum prop valve
Last edited by Heftynoma; Jun 8, 2020 at 09:40 PM. Reason: Merging consecutive posts - Per the rules of the forum, use the edit feature to update your previous post rather than posting back to back.
Old Jun 8, 2020 | 09:46 PM
Nfbfj Nxhe's Avatar
Nfbfj Nxhe is on a distinguished road
Default Does this thing have ladder bars?
Does this thing have ladder bars? Asking for a friend
Old Jun 10, 2020 | 09:58 PM
Heftynoma's Avatar
Made a bracket for my prop valve
Got about 20’ of brake line, probably gonna need a little more
Old Jun 10, 2020 | 10:30 PM
I like the progress! And the backstory lol
Not going to lie though, I'm a little concerned about the use of what looks like the 90 amp 120v Harbor Freight flux core welder used to stitch together a SAS. I have the same welder and I wouldn't trust it to get enough penetration to weld a new tongue to my trailer lol
Old Jun 10, 2020 | 11:23 PM
Cool build. I'll be looking forward to more updates!
Old Jun 11, 2020 | 06:29 PM
Heftynoma's Avatar
Got all my drum parts and ball joints. Also got the filter fitting to put it on the block. The welder is a 220 flux core and it can burn holes in 1/2 steel if I wanted to. Not a concern at all.
Old Jun 11, 2020 | 06:42 PM
Lol okay that's good then
Old Jun 19, 2020 | 03:53 PM
Heftynoma's Avatar
Brake line holder, just need to use my dads hydro flare tool and lines are done.
Packed bearings, new outer seals
Breather and brake hose bracket
Cutting off and folding my quarters
Started on a rear bumper
Made a winch mount
the ford steering arm was giving me problems so I turned the studs in to bolts.
Got the stock bumper to fit over the winch. Look closely it’s in there.
3” intake and still using the stock air box and filter.
Finished my rear bumper.
Update 8-10-20 Took the bed off
Took this cross member out, stock shock mounts and all the spare tire bs. I will be mounting a sway bar to the crossmember before I reinstall it.
Fixed rotted cab/bed mount.
Spare tire crossmember turned in to sway bar mount
Full droop links for sway bar
Painted front cover silver
Update 8/21/20 Hole for body mount
Welding can mount back on
Fully welded sway bar mounting spots
Old Aug 21, 2020 | 08:22 AM
Coming along. Looks good.
Old Aug 22, 2020 | 08:42 PM
Heftynoma's Avatar
Front brake hose bracket.
