i wonna do a lift what shud i do???
Old Jun 17, 2009 | 09:40 AM
Frenchyap30's Avatar
Frenchyap30 is on a distinguished road
Default i wonna do a lift what shud i do???
hey everyone, i have an 03 4x4 blazer with the zr2 package and i might do a lift to try n fit bigger tires..i dont care wether its a body lift or suspension but im looking for somewhere from 2-4in of lift. I wonna keep my ride quality and i heard cranking the t-bar is a really bad idea so i dont wonna do that. Any ideas on a lift that will work for me?
Old Jun 17, 2009 | 01:22 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
a 2" body lift will be the cheapeast and easiest route and with a 2" lift on a zr2 youll be able to fit 33x10.50's without and problems.(if you stick with stock rims or aftermarket rims with 6" of BS)
Old Jun 17, 2009 | 02:01 PM
thanks...can i go any wider on the tire like 11.5 or 12.5? and would 5.5 inch backspacing be ok? instead of 6
Old Jun 17, 2009 | 05:18 PM
sorry for editing tht 5 times too btw lol
Old Jun 17, 2009 | 05:45 PM
mikeinwi's Avatar
you could go with 5.5" BS if you want and you may have to trim some with a 11.50 wide tire and with a 12.50 wide tire youll have to trim for sure and you may run into rubbing issues also a 12.50" wide tire is to wide to run on stock rims.
Old Jun 17, 2009 | 05:50 PM
or any other back spacing?
Old Jun 17, 2009 | 05:53 PM
mikeinwi's Avatar
you can run any backspacing you want, but keep in mind that the lower the backspacing the more youll have to decrease your tire size.
Old Jun 17, 2009 | 06:00 PM
ok so if anything go up
Old Jun 17, 2009 | 06:02 PM
mikeinwi's Avatar
i would just stick with the stock 6" backspacing.
Old Jun 17, 2009 | 08:57 PM
thanks i think im guna go with these rims: http://www.summitracing.com/parts/ARE-450516160/
with these tires: http://www.discountedwheelwarehouse....ShowLarge=True
and a performance accesories two inch lift
