if i have a 4" lift could i fit 15x10
Old Oct 28, 2007 | 08:00 PM
yamahakid's Avatar
yamahakid is an unknown quantity at this point
Default if i have a 4" lift could i fit 15x10
if i have a 4" lift could i fit 15x10 or would it work if i was 6" in the air ona suspension lift
Old Oct 28, 2007 | 10:36 PM
mdehoogh's Avatar
Default RE: if i have a 4" lift could i fit 15x10
what year is your truck and what size tires would you be running
cyukio recently made a similar thread. hes got a 2wd with a 2" body lift, 3.5" lift spindles and add-a-leaf so hes at about 5.5" he had problems with a 30x11.5" tire on 15x10" wheels and said hes going to try 29" tires. however 29" tires pretty much the same height as stock
Old Oct 29, 2007 | 08:33 PM
yamahakid's Avatar
its a 95 atleast 30
Old Oct 29, 2007 | 10:39 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
15x10's aren't really a good idea on these trucks. They're entirely too wide, and don't come with nearly enough backspacing. You won't be able to fit any large tires, and you'll chew through your front end like nobody's business. I'd stick with a 15x7 with 4"+ of backspacing or a 15x8 with 5"+ of backspacing.
Old Nov 2, 2007 | 10:45 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
I would go with a rim that was not as wide as that not over 8 i think,with the 10 it will rub the sway bar/frame.
Old Nov 3, 2007 | 12:17 PM
cyukio's Avatar
cyukio is an unknown quantity at this point
yup i totally agree with what everybody in this post said. 15x8 is the way to go my 15x10s is just not giving me the results that i wanted. here i am waiting for the 29s to come in and i dont really think theyre gonna fit without trimming or rubbing either. my advice go with whats recommended or if you got the money "STRAIGHT FRONT"!!!!!
Mcg89
Feb 15, 2014 08:37 AM
KidBlazer
Tires and Wheels
Feb 9, 2013 08:26 PM
Sephirots
Jan 11, 2009 04:46 PM
cyukio
Tires and Wheels
Apr 18, 2007 06:35 AM
