Just want a small lift
I have a 2000 Blazer LT and was looking into raising it about 2", just to get the frame harder to bottom out. Now the things i am a little, i guess, confused about is the process of the t-bar raising. After you raise that to 1.5" what would you do then?
Any help would be great As a side note I was looking at Wolfpack's blazer and would like an end result like that. |
im pretty sure hes got shackles along with the tb crank which should give you about 1.5-2in, but hes also got a body lift which wont make the frame less prone to bottoming out another option for lift would be the 2in suspension lift and i beleive theres a 6in and 5in also. if you dothe tb crank just turn the bolt until you reach the height ur after then get an alignment andu should begood to go.
Originally Posted by mikeinwi
(Post 205626)
if you only crank the bars enough to get the 1.5-2" youll be fine, its been discussed multiple times that a 1.5-2" crank is a safe amount of lift. u may see some pre-mature wear but its not like ur gonna be out every month replacing cv's and ball joints.
