Leaf Spring Shim Question
Old Apr 11, 2011 | 07:13 PM
tony991's Avatar
tony991 is on a distinguished road
Default Leaf Spring Shim Question
I installed the 5" trailmaster lift a while back on my blazer. The yoke hits the driveshaft really hard when I brake real hard in emergency stops.
I'm looking for tapered leaf spring shims but all I can find is shims with two alignment holes. I need the ones that have the tit and the hole. Does anyone know where I can find them?
I don't really want to use lift shackels because the leaf spring bolts are always seized.
Old Apr 11, 2011 | 07:53 PM
NVANZEE's Avatar
I got mine from suspension connection. I think they were like $20.
Old Apr 11, 2011 | 08:40 PM
warthogdriver's Avatar
Originally Posted by tony991
.............two alignment holes. I need the ones that have the tit and the hole. ...........
sorry i had to, childish i know. read it above.
ok, now the serious part.
how do you know if you need shims?
i have the 5" bds lift and 2" shackle lift in back.
i just had to replace my u joints, the front set (close to tranny) failed just short of coming apart.
now i have never changed them since i have had the truck...7 years almost.
could it be coincidence?
Old Apr 12, 2011 | 08:03 AM
tony991's Avatar
There is too much of an angle on the driveshaft.. When I brake the diff. points down slightly due to axle wrap. The yoke from the t-case hits the driveshaft making a god awful noise. I can see the metal to metal contact on the yoke.
Attached Thumbnails Leaf Spring Shim Question-dsc00210.jpg   Leaf Spring Shim Question-dsc00211.jpg
Old Apr 12, 2011 | 08:06 AM
I'm not sure that you are going to gain much by changing the pinion angle at the rear diff. It looks like you need to drop the transfer case & transmission mount down some to correct that angle.
Old Apr 12, 2011 | 04:10 PM
so, can the transmission mount be "shaved" or would that effect the structural strength of the mount.
mine looks similar but not that steep i think
Old Apr 12, 2011 | 09:29 PM
tony991's Avatar
Suspension Connection only has the ones that have the centering pins/alignment holes on both sides.
98BlazerT4X4
Lifting Tech
Mar 26, 2014 10:20 PM
420Blazin4X4
Lifting Tech
Jun 4, 2012 10:17 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
team prodigy james
Aug 13, 2010 06:45 AM
mpaczosa23
Lifting Tech
Feb 12, 2009 06:53 AM
