leveling kit help
Old Jul 9, 2009 | 01:08 PM
  #21
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
any 2" lift shackles will get the job done. check out ebay if you cant find any locally.
Old Jul 9, 2009 | 01:43 PM
  #22
oktain's Avatar
Shackles are what link the rear leaf springs to the frame, getting longer ones will lift the rear of the truck.
Old Jul 9, 2009 | 01:44 PM
  #23
mdehoogh's Avatar
They connect the leaf spring to the frame. synergyoffroad.com carries them and 3leaffab.com has some too. I didnt check to see if either have them in stock though
My stock shackles
Wolfpack's lift shackles
Old Jul 9, 2009 | 01:55 PM
  #24
bandidolenny's Avatar
Old Jul 9, 2009 | 07:42 PM
  #25
Jfutch101's Avatar
Jfutch101 is on a distinguished road
ok thank you all how many do i need to buy and so its 2in shackles for 1.5in lift?
Old Jul 9, 2009 | 11:39 PM
  #26
mikeinwi's Avatar
youll need 2 shackles, one for each side.
Old Jul 10, 2009 | 06:54 AM
  #27
Jfutch101's Avatar
ok ty
wouldnt i need to get 1.5in shackles for 1.5in lift so that it is level in the front and back?
Old Jul 12, 2009 | 08:59 PM
  #28
Shotgunn99's Avatar
Shotgunn99 is on a distinguished road
No, your really not going to be able to tell the difference with 2in shackles and 1.5 tbar.
Old Jul 13, 2009 | 02:59 PM
  #29
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
I cranked my t-bars and did not add shackles in the rear b/c of the extra weight of the bumper, but I only have 30 in tires. I can tell you it didn't rub AT ALL on the trails in CO, even on the switchbacks and hairpins. I was worried at first, but lemme tell you, crank those bastards and get the alignment!
Old Jul 16, 2009 | 06:56 PM
  #30
leeclark's Avatar
leeclark is an unknown quantity at this point
i cranked my tbars also got the shackles at autozone and welded a piece of square tubing in them they work fine i'm running 31x10.50s on a 2" lift had to trim the inner fender well a little. going to get alignment tomorrow.
