leveling kit help
Old Jul 18, 2009 | 12:27 PM
  #31
Jfutch101's Avatar
Jfutch101 is on a distinguished road
i found a 2in suspention lift that im going to buy and it will be alot better for the truck with it
Old Jul 18, 2009 | 01:23 PM
  #32
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the 2" suspension lift is a huge waste of money IMO. it just allows you to crank your tbars even farther putting unwanted stress on your front end parts(mainly cv's) just save your money and crank your stock tbars 1.5" it is free afterall. if you do have your heart set on the 2" susp. lift i would suggestion you read through this thread first >> https://blazerforum.com/forum/lifting-tech-44/2%22-suspension-lift-gremlins-26616/
Old Jul 18, 2009 | 09:03 PM
  #33
Jfutch101's Avatar
the rough country lift comes with new ball joints and upper control arms
Old Jul 18, 2009 | 09:05 PM
  #34
mikeinwi's Avatar
it does but your cv's still take a pounding.
Old Jul 18, 2009 | 09:36 PM
  #35
Jfutch101's Avatar
oh then why would a suspention lift of 2in be bad and a 5in lift not be worse? or cranking up the tbars? and what wear will it give the truck?
Old Jul 18, 2009 | 10:07 PM
  #36
mikeinwi's Avatar
ok i take it you havent read the thread i linked earlier, so here it is again>> https://blazerforum.com/forum/showthread.php?t=26616. the 5" and 6" kits include items that drop your front diff which helps to maintain your factory cv angle.
Old Jul 19, 2009 | 07:07 AM
  #37
Jfutch101's Avatar
i read it i just didnt understand it so i need to get a front diff drop of 2in?
Old Jul 19, 2009 | 10:47 PM
  #38
mikeinwi's Avatar
unless you buy a 5 or 6" lift kit you cannot lower your front diff.
Old Jul 20, 2009 | 06:22 AM
  #39
Jfutch101's Avatar
ok so how long would it take to wear out the parts
Old Jul 20, 2009 | 12:45 PM
  #40
mikeinwi's Avatar
it depends on what kind of shape theyre in now its not really something you can put a timeline on every blazer is going to be different.
