leveling kit help
Old Jul 21, 2009 | 09:03 AM
  #41
Jfutch101's Avatar
Jfutch101 is on a distinguished road
ok so what will be wearing down and what will it look and sound like when it does
Old Jul 21, 2009 | 10:09 AM
  #42
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Im running into the issue where i cant crank my tb. there already cranked as far as they can go. i want to lift it,but i dont want a body lift an i cant afford the 5 or 6 in lifts so my only option would be the suspension lift right? anybody got any other opptions?
Old Jul 21, 2009 | 11:20 AM
  #43
mdehoogh's Avatar
Your CV SHAFTS will wear out faster than normal. On this youtube video, at 1:46 it shows what happens to CV shafts when pushed at an angle. Cranking your tbars (or installing a 2" rough country kit) will do that.
Why can't you crank your tbars? Have you already cranked them all the way up?
Old Jul 21, 2009 | 04:20 PM
  #44
Jfutch101's Avatar
ok ill watch the vid
Old Jul 22, 2009 | 10:12 AM
  #45
Why can't you crank your tbars? Have you already cranked them all the way up?[/QUOTE]
I cant crank them because the previous owner must have had some work done on it. so now the bolts are almost in all the way i cant even get 3 turns out of them.
Old Jul 22, 2009 | 10:17 AM
  #46
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
cranking your tbars all the way up will destroy your cv's, any tbar crank will put added stress on the cv's and shorten their life span. unless you have the funds to constantly replace front end parts cranking the tbars all the way up is a horrible idea.
Old Jul 22, 2009 | 10:21 AM
  #47
Thats why i dont want to crank the tbars. I guess theres no real way to lift my blazer unless i do a body lift, but i dont like how those look. so basically i either dont lift it at all or get a 5 to6 in. lift which i wont be able to afford for a long time
Old Jul 22, 2009 | 10:26 AM
  #48
mikeinwi's Avatar
you can do a 1.5" tbar crank it will cause accelerated wear with the cv's, but its a very common crank and seems to be a happy medium.
Old Jul 22, 2009 | 10:28 AM
  #49
I cant crank them that much on the driver side i have 3 turns and the passenger i have 4.
Old Jul 22, 2009 | 03:45 PM
  #50
oktain's Avatar
looking at your truck from the side... is the front end level with the rear? or is the front lower by ~1". Could be the previous owner has already cranked the T-bars (and would probably be the case if your truck sits level.). If that's the case, I wouldn't touch the T-Bar bolts, if you bottomed them out you're going to go through CV axles like a Peterbilt through a crowd of people.
