lift question
Old Oct 21, 2007 | 08:59 AM
Whitey96's Avatar
Whitey96 is an unknown quantity at this point
Default lift question
Im interested in liftin my 96 blazer and Im not really sure what a good suspension lift would be. Im not lookinto spend a wholelot of money but would like to get a good lift kit. I dont like the looks of body lifts so Im really only interested in suspension lifts.Hopesomeone will be able to help give me some info. Thanks Yall
Old Oct 21, 2007 | 09:24 AM
mdehoogh's Avatar
Default RE: lift question
it depends on how high you wanna go. its pretty much either 2" or 6".... the 2" lift consists of crawling under your truck and tightening the torsion bars, buying lift shackles for the rear and getting an alignment...
stay away from a 2" lift kit unless you just really really want it. they are about $650-$750, and it is the same thing i mentioned above which you can do yourself for about $120-$150
Old Oct 21, 2007 | 08:52 PM
Whitey96's Avatar
Thanx for the response otnietdehoooo. I take it that those are the only two lift kits. I was really just wantin to go up bout 3". I dont want to go to high cause I dont wanna have to buy a whole lot of new stuffafter I install the lift. Any recomendations on brands or places to get the lift shackels?
Old Oct 22, 2007 | 08:12 AM
mdehoogh's Avatar
synergyoffroad.com is a great place to buy things. its all offroad parts for blazers and s10's and colorados. im not sure on pricing... im still trying to decide if i want to lift and how to go about it if i do.if you have the right machinery, you could make them yourself. blazin_jason recently made a thread about making them himself.
Old Oct 22, 2007 | 09:05 AM
nj4x4blaze's Avatar
Good lift kits in IMO are BDS 5" and Superlift 6". You can also just do a body lift as well. They offer 2" and 3" body lifts.
Old Oct 24, 2007 | 02:18 AM
ga_repoman's Avatar
ga_repoman is an unknown quantity at this point
[8D]about the only way to get 4 inches over stock is a tb crank with a shackel or add-a-leaf in the rear + a 2 in bd lift then larger tires 31's or 32's
I can get 30's on my stock 01 without any problem ...
Old Oct 24, 2007 | 10:51 AM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
So 30's will fit stock height without any rub? whats the width of the tires?
Old Oct 24, 2007 | 11:00 AM
nj4x4blaze's Avatar
ORIGINAL: Idriveachevy
BFG All Terrain Tires 30/9.50R15LT
BTW, are you planning on using your stock rims?
Old Oct 24, 2007 | 12:16 PM
well, im looking at the black steel rims cause i like how they look, but i havnt taken size into much consideration, and i have no idea what the hell the offset and bolt patters should be.
Old Oct 24, 2007 | 10:56 PM
mdehoogh's Avatar
im not real sure about stock offset, but the boltpattern will be 5x4.75 and if you have a 4wd the backspacing is 6". 2wd has 4" backspacing...
if you getwheels with less than stock backspacing, (ie 4" inestead of 6") it will push your wheels further out which can cause rubbing problems
