lift question
Old Jun 21, 2009 | 10:36 PM
sk8indigomoon247's Avatar
sk8indigomoon247 is an unknown quantity at this point
so it prolly wont do TOO much damage? haha cant be hurting on the wallet, if its gunna end up costing alot im not gunna do it.
but if i do just get the 2" body can i fit 31x10.5??
Old Jun 21, 2009 | 10:42 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if your using the stock rims or rims with stock specs a 31x10.50 tire should fit with no problems.
Old Jun 22, 2009 | 12:45 AM
bandidolenny's Avatar
Just don't go nuts when cranking the t-bars...
Old Jun 25, 2009 | 10:57 PM
ok ive got a new question, is doing a body lift really that hard? those instructions say to have proffesionals do it,
im just wondering like would it be hard to find a like shop to do it?
also if i just did the t-bar and shackles could i get bigger tires? or no?
Old Jun 25, 2009 | 11:00 PM
mikeinwi's Avatar
most people can knock out a body lift in a day or two, but if you do not feel confident enough installing it on your own most shops should be able to do it for you. if you decide to skip the body lift and just do shackles and a tbar crank you can fit 30's no problem or 31's with some trimming in the front(if using stock wheels)
Old Jun 25, 2009 | 11:16 PM
ok it just depends im prolly not gunna get tires till the end of summer around august
can you tell me something about these?
http://cgi.ebay.com/ebaymotors/ws/eB...m=120437568615
what does that do? hard to install? anything like that?
also sorry if im bothering you, im young/dk anything about this stuff
and i wanna make my blazer look good lolol
and would these shackles work?
http://cgi.ebay.com/ebaymotors/SHACK...623159008r2171
i may just do this for a while untill i can decide if i wanna do the body lift or not
Old Jun 25, 2009 | 11:24 PM
mikeinwi's Avatar
the shackles should work with no problems, but IMO i wouldnt waste money on new keys just crank your stock tbars 1.5" and youll be fine.
Old Jun 25, 2009 | 11:27 PM
ok thanks i might do this within the net couple of weeks ill keep this updated as to how it goes
and btw in my pictures. does my blazer look kinda low to you?
like my mom has a 2002 ls 4x4 and hers is like a few more inches higher than mine dk what it is or anything but i was jw everybody says its low
Old Jun 25, 2009 | 11:33 PM
mikeinwi's Avatar
its kinda hard to tell from the pics in your album, but just measure your blazers height from the ground and compare that to your moms blazer. measure from the bottom of the fender above the wheel to the ground and repeat that at all four corners then do the same to your moms blazer and compare to the results.
Old Jun 25, 2009 | 11:36 PM
what if its like WAY off
oh and btw we took it to the shop and they said that the front sus. is like shot haha
and we need all 4 new shocks soon
could that have something to do with it?
