Lift shackles
Old Oct 5, 2007 | 07:25 PM
Blazin_Jason's Avatar
Default Lift shackles
Hey I thought I would try to build a set of lift shackles. Made them out of 1/4" 2" flatbar and braced with 1/4" wall 1.5" sq tubing. They are 3" longer than stockers and should provide 1.5" of lift. Although the 1/4" is thicker than stock, I would probably go with 3/8's. I wanted 5/16's but wasn't available at the time. Then of course I sand blasted and powder coated them.
Here is a shot with a stock shackle beside it.
Old Oct 5, 2007 | 07:30 PM
Default RE: Lift shackles
Looks good! And as you have found out, there really is nothing to it! Just a welder and some metal!!
Old Oct 6, 2007 | 06:12 PM
Yup pretty straight forward to build. As long as you have access to a welder and some of the right tools, anyone can do it. I love my millermatic 175. Hopefully I can put them in this weekend. For anyone who wants to give it a go, stock shackles are 4" from center to center of the holes. For any extra length you add will give you half that amount in lift. So 8" on center will be 4" longer than stock and yeild about 2" of lift. The space required between them, where the bushings go is 3". So the square tubing I used was 3" long. The holes I drilled were 9/16's. Now hopefully all that information is correct and they will fit.
Old Oct 6, 2007 | 11:22 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Looks nice, what did it cost you to make them? I am interested in doing this but don't have my own welder, but have a couple friends that could weld em up. I also like the powdercoating. very nice and professional looking. Will yours be greasable?
Old Oct 7, 2007 | 01:48 PM
ORIGINAL: lennyblazer
I spent like $20 for the flatbar which is enough to do another set and a bit. I already had the square tubing. Mine won't be greasable, never really thought about that. What would have to be done to make them greasable?
Old Oct 7, 2007 | 03:27 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Nicely done!!!
Old Oct 7, 2007 | 11:45 PM
I am not sure I believe it is just the bushings that you would put in place of the stock ones where the shackles mount. I just know that daystar sells greasable and non greasable for like $10-$15 dollars difference.
Old Oct 8, 2007 | 11:04 AM
No these won't be greasable then. If I can find the greasable bushings, then I can put them in later. $90 for the greasables and $63 non each, but I would hope its for a pair. Those are some nice looking pieces for sure.
Old Oct 8, 2007 | 03:45 PM
Got them in this morning. I just put lots of anti seize on the bolts. Luckily I didn't encounter any problems. Got them installed without any issues.
Couple befores:
After pics, now 1 1/2"s higher. I will be replacing the tie rod ends soon and will crank the torsion bars slightly. Gotta get an alingment after the new tie rods, so might as well lift it a little.
Old Oct 9, 2007 | 07:01 PM
Looks good!!! Are you going to crank the t-bars up at all?
