lifting info
Old Oct 27, 2008 | 05:00 PM
jagblazer01's Avatar
Default lifting info
so im starting to save so I can do my lift. More then likely going to do either the super lift or BDS 6" kit along with a 3" body lift. I was told by a shop here that I can fit 35s with this combination with minimal trimming. Is this true or not? I really would like to go with a bigger tire the 33s.
Old Oct 27, 2008 | 06:01 PM
vin791's Avatar
vin791 is an unknown quantity at this point
Default RE: lifting info
you will rub frame if you try to turn. other than that, yeah you can fit 35s.
Old Oct 27, 2008 | 07:16 PM
WolfPack's Avatar
Just dont wheel it....you'll break stuff real easy with 35s.
Old Oct 27, 2008 | 09:07 PM
yea i hadnt planned on doing any wheeling with it.....another thing...do I have anything to worry about with wear and tear on the motor??
Old Oct 27, 2008 | 09:36 PM
Blazin_Jason's Avatar
You will more than likely need to re-gear the diffs as well.
Old Oct 27, 2008 | 10:21 PM
i know about the rear end...i planned on doing 4.10s
Old Oct 28, 2008 | 12:35 AM
vin791's Avatar
you should be good to go, but yeah the engine is under more stress, one thing is it will lowwer mileage and power significantly
Old Oct 28, 2008 | 12:54 AM
WolfPack's Avatar
Thats why you re-gear...keep the mileage and power the same as (or better than) stock. The only real difference after the lift and regear should be braking...but that can be upgraded too
Old Oct 28, 2008 | 12:09 PM
mdehoogh's Avatar
ORIGINAL: jagblazer01
I'm sure you know this but you didn't say anything about it. You will need to regear the front as well
Old Oct 28, 2008 | 01:01 PM
WolfPack's Avatar
If he keeps it 4wd
