-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   need help with lift shackles (https://blazerforum.com/forum/lifting-tech-44/need-help-lift-shackles-81333/)
big_charms@hotmail.com Aug 27, 2013 05:49 PM
I'm making lift shackles for my ZR2. My stock shackles measure out to 4inches center bolt to center bolt. Now for my under standing is to gain 2 inches of lift the measurement would have to be 8 inches center to center. Can someone please verify this
TMM217 Aug 27, 2013 07:24 PM
I wanna say my shackles are 6 inches apart on my non ZR2 blazer but that makes sense to me to just add 2 inches. Have you done a search to find help.
big_charms@hotmail.com Aug 27, 2013 07:37 PM
I have searched and for what I can find is that every inch added with give a half of a inch. Makes since to be because your Not moving both ends just one end down
rexazz2 Aug 27, 2013 08:12 PM
I would guess +2" on stock
your only moving one end however its not straight up and down ???
old school car shackles had multiple holes on the spring end for adjustment
google car shackle images
BTW when you look at online images for blazer ones , look at the proportions ???
big_charms@hotmail.com Aug 27, 2013 09:09 PM
I have be searching. Maybe I just haven't searched the right thing yet but The closest thing I have found is
Measurement bolt hole to bolt hole = amount of lift
4"= stock
6"= 1" of lift
7"= 1.5" of lift
8"= 2" of lift
9"= 2.5 " of lift
10"= 3" of lift
I don't remember where I found the measurements
Thogert Aug 27, 2013 09:44 PM
Yeah since you are only moving one side of the leaf springs, the amount of lift you get is going to be about half, until you get a lot more length than stock.
big_charms@hotmail.com Aug 28, 2013 03:33 PM
I Got The day off today so I made my shackles today.
I was looking to get 2.5 inches of lift
The measurement of bolt hole to bolt hole is 9 inches apart
Which have me exactly 2.5 inches of lift
rexazz2 Aug 28, 2013 03:38 PM
I didn't realize you were local
You could have made a second set :icon_deal:
big_charms@hotmail.com Aug 28, 2013 03:48 PM
Lol I would if I had The steel. I Just had a few pieces laying around which was just enough to make one set. It was really easy to do. All I had was a grinder and a corded drill.
rexazz2 Aug 28, 2013 05:32 PM
actually I put in a set of air shocks and they run it a little higher than stock
