PLEASE HELP!... lift kit options.
Old May 14, 2007 | 01:42 PM
manfish's Avatar
manfish is an unknown quantity at this point
Default PLEASE HELP!... lift kit options.
Whats up guys,
I have a 2000 Jimmy 2dr, 2wd. I am in need of some new tires really bad andi want to go with a 2" body lift and a 2" suspension lift while i am at it. The problem is i cannot find any lift kits that will fit my 2000 jimmy! Could you guys please direct me in the right direction to a manufacturer that sells kits for 2wd, 2dr.... This combo will clear 32" tires right? Any input is greatly appreciated.
thanks
-manfish-
Old May 14, 2007 | 02:00 PM
Default RE: PLEASE HELP!... lift kit options.
I'm surprised that you have not turned up any results for your truck...
Superlift makes a 2" suspension lift, however, it consists of torsion keys to jack up the front suspension which puts the control arms at steeper angles and can lead to premature wear on the ball joints which are problem prone for some.
Old May 14, 2007 | 02:24 PM
manfish's Avatar
thanx kyle...
-manfish-
Old May 15, 2007 | 12:48 AM
eo1davista's Avatar
eo1davista is an unknown quantity at this point
i'm looking to do the same thing with my 2004 Blazer and found a 2" suspension lift from roughcountry.com that was recommended from these folks and doesn't put the wear and tear on the ball joints, as well they do have 2" body lifts for your year as well.
Toby
Old May 15, 2007 | 08:01 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
The rough country lift still doesn't do anything to alleviate the wear on the CV's from cranking your t-bars.
IMO, those "levelling kits" are a waste of money. Do a modest t-bar crank and install a set of shackles instead. You'll end up saving hundreds of dollars.
Old Aug 8, 2007 | 06:33 PM
motoracer12's Avatar
motoracer12 is an unknown quantity at this point
i found a kit for the 2000 4x4 on EBAY for 200 shipped that has rear shackles and torsion bar keys.
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
jjsmith1228
Oct 31, 2010 03:56 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
manfish
Suspension Tech
May 14, 2007 01:47 PM
Arthur
Suspension Tech
Apr 16, 2007 06:40 PM
