Questions on Body Lifts
Old Apr 5, 2011 | 07:45 PM
Spin87's Avatar
Spin87 is on a distinguished road
Default Questions on Body Lifts
Hello!
So lets get down to the nitty gritty. I have a 92 S10 Blazer 4.3L. I am getting ready to install a 3 inch body lift this weekend. So I sat down read through the paper work and all that good junk they sent with it. Found a bit of a concern I had and decided I would hit up the dealer ship on it as I was unsure of it. Though they werent much help. So here I am. Ok so basically it stated that I need to check the lines running to the remote oil filter to ensure that I have enough length to do the 3 inch body lift. Now has any one had any issues with those said lines? If so where can I find longer ones as I cant even find anything on those as a replacement part.
Thanks in advance!
Old Apr 5, 2011 | 08:24 PM
warthogdriver's Avatar
well this might help...
i have a 99 and did a 2" lift....i had no problems at all with those lines.
no granted i have replace the oem lines with tranny cooler rubber line and adjustable clamps to the oem alum connections on the relocater bracket. i did keep them the same length as stock though.
so no length issues but that might give you an idea as to how to lengthen them if you need to.
Old Apr 5, 2011 | 08:34 PM
tony991's Avatar
tony991 is on a distinguished road
I put a 3" body lift in my 1988 S-10 Blazer and the stock ones were long enough. You just drop the oil filter down a bit.
Old Apr 6, 2011 | 02:57 AM
Spin87's Avatar
Hmm ok that's good to hear! Well ill toss some pics up once I get the lift done...btw I took your advice already once tony on the shift linkage! Appreciate the info.
dsline
Lifting Tech
May 2, 2010 09:47 PM
UwharrieMan
Lifting Tech
May 27, 2009 02:05 PM
RedNeckWagon360
Apr 3, 2009 11:53 AM
Boyer2011
Lifting Tech
Mar 17, 2009 08:10 PM
keithscianna
Jun 22, 2006 01:59 AM
