burningsun |
05-30-2009 11:09 AM |
Rough Country 2 inch kit
4 Attachment(s)
I know Bandi has posted a thread about his issues with the 2inch kit from Rough Country. I'm have some issues also, nothing too big. But I'm pretty sure I've found a fix for the CV issues and its nothing to do with lowering the angle of the CV. Though a CV that would opperate at more extreme angle would totally kick ass. My problem even before lift was that the CV boots would rub against the shock. I'm pretty sure the spitting everyone talks about is because the boot will eventually get to thin and a hole will develop. Yes the higher angle will help push the grease out even more. There is a kid who works at auto zone here that has a 98 s10 he has shackles and the torsion keys and body lift. He was having the same problem with the CV rubbing the shock (he had Rough Country RS9000 shocks). He replaced the front shocks with a Monroe from a Forerunner, smaller diameter and did not rub the boot... He has had this set up for over a year now and has yet to have any issues with the CV's. I really like how the shocks handle off road so I'm just going to relocate the lower mount away from C-V about 1/4 to 1/2 inch that'll clear the boot just fine. There where some issues about the caliper bolts hitting the edges of the new control arms,... I have replaced the bolts and put lock washer on them, the stock ones keeped backing out. I did this last year. I just took a 1/3 inch from the corner off. No more problems there. So far I'm still glad I got the kit. Here are a few pictures. I already have been running about 1.5 to 1.75 inch front and 1.25 to 1.5 in the back. So I only got 1/2 to 3/4 an inch in the front over the before set up and 2 inches in the rear. So my rear sets about an inch higer than the front. But now it drives straight and keeps the alignment even after I've taken offroad. To be honest it drives as well as it did with half the miles and Now modifications...HELL I'm not even running my sway bar. Well... time to start making some shock mounts..
