shackle lift
hi i found this kit for a shackle lift at a parts store close to my place, its only 20$ i wanted to know if this is any good, thanks, also do you need anything else to extend the shocks or something? thanks
http://ecx.images-amazon.com/images/...500_AA300_.jpg |
Noooooo. Don't buy the cheap lifts like that, they aren't designed to handle much use at all. Best case scenario when it fails is you slam on the brakes and come to a screeching stop when your ass end hits the ground :)
Look for machined shackles from people like 3leaffab. They have some pretty good ones, a lot of the guys here including myself have a set. As far as shocks your stock ones will do just fine. make sure you disconnect them when you put the shackles on though, makes it much easier to align the bolt holes. And depending on age/rust, look into new leaf spring bushings. Might be a PITA to change, but 3 of mine went bad when me and my buddy were putting my shackles in. |
I have a set on my truck and I welded a suport in and they work just fine.
I have them too and they work fine
Originally Posted by acidwarning
(Post 356266)
Regardless of how many people have the cheap shackles, they still won't last as long as a good machined pair no matter what you do to them. It's simple logic there. It's up to you how much you spend on them in the end, however.
Originally Posted by CNYCountryKidd
(Post 356572)
I have had to replace my bolts several times and the highway ride isn't that great I don't think I would recommend them either... but they do work
thanks guys, i think ill wait for something else...not always easy finding stuff here with decent shipping though since im in canada :p and my speed shop only found ones for jeeps not blazers
