Shackle questions
Old Jan 26, 2008 | 05:53 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default Shackle questions
I got my shackles in and I started to install them but things didnt go to well
So heres my questions...(I bought Jiggs shackles)
- one side is longer than the other... ===|== like that...which side goes up? the longer side right? or does it really not matter?
- also when installing, I lift from the frame to release the load on leafs...then just support the axle while removing the shackles?
I dont want to do this wrong and release the shackle when the load is still on the leaf and have to go to the emergency room/
-How do I remove the top bolts (2 door, 4x4 2000) ... Just reach up there? Or do i have to remove the gas tank?
- Also since it will be lifted 2 inchs does the driveshaft become a worry?
Old Jan 26, 2008 | 06:24 PM
YepIOwnA97Blazer's Avatar
YepIOwnA97Blazer is an unknown quantity at this point
Old Jan 26, 2008 | 06:37 PM
Zasder's Avatar
Default RE: Shackle questions
Very nice!
I had the same exact lift points! but at our shop the master mechanic told me to stop becuase Im going to loose my arm because the spring will snap back!
WTF! [:@]
Old Jan 26, 2008 | 07:15 PM
Blazin_Jason's Avatar
Oh so you must work at a dealership :P
Old Jan 26, 2008 | 07:17 PM
Zasder's Avatar
Goodyear
Old Jan 28, 2008 | 08:54 PM
navyblue_sk8er's Avatar
navyblue_sk8er is an unknown quantity at this point
I have a 2001 2dr 4x4 and you can get the top shackle bolts out without dropping the gas tank. If anything you will only have to remove the plastic shroud around the gas tank. As for the driveshaft you have nothing to worry about, it'll be fine. The shorter side of the shackle should go to the bottom. At least thats how I installed it according tomy suspension lift instructions.
Old Jan 28, 2008 | 08:59 PM
Zasder's Avatar
Hey thanks man,
they were installed yesterday
My a$$ end is hanging up 2 inches higher, but I cant crank the T-bars, cuz they are already sagging and its a whole mess...hahaa
Old Jan 28, 2008 | 09:54 PM
cliro's Avatar
cliro is an unknown quantity at this point
[sm=chairshot.gif]pics..
Old Jan 28, 2008 | 10:07 PM
So why did you install shackles in the back if you can't crank the T-bars? Were you intentionally going for a high rear end look? Get some pics up soon.
Old Jan 29, 2008 | 09:56 AM
blazinblack's Avatar
blazinblack is an unknown quantity at this point
where did you get the lift shackles from and how much were they?
[align=left] [/align]
