Starting a SFA project
Old Sep 1, 2010 | 05:23 PM
02BeachBlazer's Avatar
02BeachBlazer is on a distinguished road
Default Starting a SFA project
Ok guys i have a couple questions. I have a 2002 blazer with a 2" bl and want more lift but id rather go for the SFA conversion route. I want to slowly start putting together a lift.
I dont want to go crazy though i just want to run 33s or 35s. Im kinda new to the whole SFA deal also. If anyone could make a list of the parts i need to do such a lift that would be great!
also im aware the doing the Sfa conversion will make the qualitly of the ride decrease but by how much?
Old Sep 1, 2010 | 05:41 PM
Benedict1337's Avatar
take a ride in an older wrangler that is lifted and has leafs in the front that will be a similar ride to what you will have with a sfa swap. I think the best axles for you would be either dana 30's or 44's. I'm not sure what else you might need , don't really know much more other than you need to be pretty good at welding and have a lot of patients
Old Sep 1, 2010 | 05:44 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
I would start HERE while I do much prefer this forum that site has tons of info on SFA readily available for reading also a section devoted to SFA builds may want to read through some of those to get an idea of what issues folks run into etc. also one of their members owns 4wdfactory and gives parts discount to forum members and is currently working with off road direct to develop a new SFA kit (leaf spring version is done and in testing atm)
Old Sep 2, 2010 | 02:42 PM
Alright thanks guys.
Im going to probably start shopping around for some Dana 44s before long
Old Sep 2, 2010 | 02:54 PM
Logan's Avatar
Logan is on a distinguished road
Its easy... Ill have a whole write up on mine in a few weeks if all goes well. Wagoneer front leafs (or rancho 44044 leafs) and pitman arm, Astro van steering box, Cherokee axles (61f,60r WMS to WMS) with the 4.10:1 gears, mounting tabs, bushings, 1st gen t-case... Ill let you know what front drive shaft you can use soon...
Wait...did I say easy... How well are you at custom fab? I find it easy... Just look at the skyline tails I made on my 3rd gen lude...
Old Sep 7, 2010 | 06:52 PM
alright im lookin forward to the write up
Old Dec 23, 2010 | 09:34 PM
POWERSTROKEN's Avatar
POWERSTROKEN is on a distinguished road
Sorry for the newb question, but can someone please explain the need for the Astro van steering box? I am planning a SAS myself. Thanks Jim
Old Dec 23, 2010 | 09:54 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
If I'm thinking right it would be in a different location or height to allow for your other components to work with out rubbing or clearance issues
Old Dec 23, 2010 | 09:56 PM
So I guess the next question is which year do you want? Thanks Jim
Old Dec 23, 2010 | 10:11 PM
ABN31B's Avatar
HERE is some more good stuff on a SAS.
and this one has a ton of pics
i believe those were the #1 and #3 returns on a GOOGLE search of "s10 sas"
