-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   t bars (https://blazerforum.com/forum/lifting-tech-44/t-bars-27843/)
lene 98 Feb 21, 2009 08:04 PM
t bars
how do you see if your t bars are up too much
swartlkk Feb 21, 2009 08:07 PM
RE: t bars
If you measure before and after and it is over 1.5" higher after, they are probably "up too much". You can go up to +2" typically with t-bars which have not sagged much, but going higher than 1.5" will cause increased wear on the ball joints and the CV shafts.
lene 98 Feb 21, 2009 08:15 PM
RE: t bars
so what if you did not measure:D
swartlkk Feb 21, 2009 08:18 PM
RE: t bars
Well I guess you are SOL then... LOL
Just need to have some kind sole report on what a "stock" truck measures on height. Having larger tires means you will have to add to the height to account for that.
Cavalier z24 Feb 21, 2009 08:42 PM
RE: t bars
how is it working out for ya?
lene 98 Feb 21, 2009 09:28 PM
RE: t bars
well just working on little things waiting on my lift
AJBert Feb 23, 2009 12:53 AM
RE: t bars
Not sure if this helps you but this is how you check on a ZR2. Can't say how it works on a non-Z.
http://www.zr2usa.com/mboard/index.p...&hl=height
Scroll down a bit and you'll see how to measure.
bandidolenny Feb 23, 2009 02:26 AM
RE: t bars
My cv shafts are at such extreme angles that when I droop a tire I get vibrations from the shafts due to the cv knuckles internally banging into each other. In other words in addition to the 2" lift, I have my bars cranked WAY beyond what the cv shafts were designed for... I replace them about every six months. I am getting pretty good at it.
