Torsion Bar Crank Tutorial
Old 02-15-2010 | 08:43 PM
vanillathrilla's Avatar
vanillathrilla is on a distinguished road
Thanks for the information! I'm picking mine up tomorrow and I want to get underneath it and see if that's how it's lifted. It's on 31's right now, and I can't tell if it's some sort of ghetto suspension lift, body lift, or maybe if it's just a t-bar crank job. We'll see.
Old 07-14-2010 | 12:59 PM
texas4x4blaze's Avatar
texas4x4blaze is on a distinguished road
i was thinking about doing this to my blazer... now would it be even better to just get the t bar keys?
Old 08-23-2010 | 08:02 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
ok, i know that when you get a alignment done, the factory alignment specs are already stored in the machine. now i cranked my t-bars to give my front 1.25 inches of lift and added 3 inch rear shackles to level out my truck and give it a little height. i know that factory alignment specs go off of factory ride height, so after my truck is lifted, wont my tires still wear unevenly because my lifted truck is aligned to factory specs? or are the alignment machines "smart" and adjust my truck so that the tires wont wear even with the added height?
Old 03-02-2011 | 10:29 AM
karatekid90's Avatar
karatekid90 is on a distinguished road
To do an alignment you attach a sensor to each wheel. when doing this, the back sensors send a laser to the front sensors and the front to each other. This reads what the angles are assuming that it is on level ground. So when adjusted it will put caster and camber into factory specs. I used to work in a shop that did a lot of alignments although I do not know how to do one on a vehicle with T-bars.
From my experiences the alignment doesn't go off of the ride height, it jsut goes off of how the tires are sitting.
Old 07-23-2011 | 12:20 AM
blazer315's Avatar
blazer315 is on a distinguished road
is this the way to go on a blazer? i want to crank the bars to 1.5 or 2 in. then get rear 2 in. shackles for my blazer and throw on some 31's.. is this a good idea?
Old 11-04-2011 | 03:56 PM
nswoodsman's Avatar
nswoodsman is on a distinguished road
Talking
A lot of people get worked up about the wear on the ball joint and cv shafts, but Rough Country makes a kit that'll help prevent it. It includes a new upper control arm with a "set of front differential brackets to maintain optimum CV angles after lifting". That's quoted right off their site. If anyone's interested, here's their site:
Chevy / GMC Suspension Lift
Old 03-04-2012 | 07:41 PM
SkMod78's Avatar
SkMod78 is on a distinguished road
I just got my 97 blazer off of the alignment rack. Found out that ride height will not affect the alignment machine, but will make it harder to set caster and camber. Longer control arms are needed if u crank up the t-bars. As for the ball joint issue, there is a company called Howe. They make ball joints for stock cars. That will go as far as 7 degrees of camber. And alot stronger then stock.
Old 01-11-2013 | 09:21 PM
hroofblaze96's Avatar
hroofblaze96 is on a distinguished road
Is this a constant problem of wear? How often is the routine maintenance of the lift?
Old 01-11-2013 | 10:52 PM
gitch93's Avatar
gitch93 is on a distinguished road
i have mine lifted with rough country 2.5 inch lift. i replaced the pitman arm,idler arm,lower ball joints,inner and outer tie rods with moog components so if they wear its under warrenty and the the uppercontrol arms from rough country has the pressed in style moogs as well. both axles have been replaced. u wont have much wear on the front if u keep ur balljoints and suspension conponents constsantly greased with good grease. i also use a needle grease fitting and punp my cv shafts full of fresh grease every now and then to keep up with the extra strain of offroading and cv angle and everyday abuse.
Old 02-15-2014 | 11:13 AM
Muddigger86's Avatar
Muddigger86 is on a distinguished road
Not sure of the 2nd generations but the 1st generations front axle/chunk can be lowered a little. If I remember correctly about 1 inch to help with angles on drive line (We used square tubing on the driver side and had to cut and re-weld the right side anchor points lower). We had to lower it a bit to do the V-8 swap on my 85. I then was able to crank the t-bars and get it back to the stock angles and achieve lift at the same time. Basically the same thing that lift companys do to lower the chuck but they do it with fancy brackets.
