want to do a suspension lift
Old May 8, 2010 | 03:52 PM
Benedict1337's Avatar
it takes maybe 2 hours at the most to put shackles on. only thing you might run into is the bushing is rusted to the bolt
Old May 8, 2010 | 05:07 PM
JimmyRiggin's Avatar
JimmyRiggin is on a distinguished road
Right, but I am wondering if there will be any clearance/reach issues, since I have already done a body lift and many cable's/vac lines are already stretched tight.
Not to hi-jack this thread or anything... just wondering if you know of anyone who has done the 2"body lift and the torsion bar/shackle lift?
Thanks.
Old May 9, 2010 | 10:11 AM
clw97bravada's Avatar
clw97bravada is on a distinguished road
I personally havent done it. I have my torsion bars cranked and have done a little research. I'm trying to do the same thing as you. Anybody can correct me if im wrong but the only things i can see getting tighter are the brake lines. With the t bar lift youre essentially stiffening your front suspension forcing the control arms down harder which pushes your truck up. Unlike the body lift it does not change the positioning of the body to the cars frame and drivetrain. The brake lines run along the control arm and the point where the control arm pivots on the frame doesnt change. I dont believe it will change anything except increased wear on ball joints, cv joints and a stiffer ride.
Old May 9, 2010 | 01:10 PM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
Thanks.
yes u can look at my 96 same setup with stock p235/75r15's and 3.75 backspaced eagle alloy rims
Old May 9, 2010 | 07:52 PM
avengedblazer's Avatar
avengedblazer is on a distinguished road
you have to be careful when lifting the front of the truck. i lifted it about 2.5 to 3in and i needed to replace the upper control arms to something with a longer reach allowing the tries to be aligned properly . and also when you crank the t-bars up even with new torsion bar keys, you are looking at replacing your cv axels offen because you are puting too much strain on it. Im looking into finding a way around this by maybe lower the trasfer case or something
Old Aug 31, 2011 | 11:41 PM
1997 Gmc Jimmy's Avatar
1997 Gmc Jimmy is on a distinguished road
Theres an Avertived 2" rear add a leff for the rear thats like a hundered bucks but people say it gives you 3"
Old Sep 1, 2011 | 12:29 PM
add a leafs lift your truck maybe an inch of lift not much more than that.
I have shackles and an add a leaf this is how it will sit
Old Sep 1, 2011 | 12:55 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
if i could imagine what my dream blazer would look like it would look like yours Benedict lol. you just have keys in the front, right?
Old Sep 2, 2011 | 07:35 AM
shwnbrun71's Avatar
shwnbrun71 is on a distinguished road
you can get a two inch lift from rough country.com but like someone said before it's a waste of money you can get almost two inches from a t bar crank but you can get the rear wheel shackles from wheelsandparts.com for 40 bucks. don't need to change the shocks or anything else
DetroitMuscle
Dec 16, 2007 02:58 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
