Well Got iT
Well I have purchased a body lift, and I have tryed to get the Body mounts in the back out, and I am having trouble removing the rear bolts I got the mounts out but I just can't get the bolts out at all.. I was reading on the papaer that came with the body lift and it says somethyng about the bolts are screwd in to the body but I wouldn't see how about going to remove them..
*Combining Consecutive Posts* OH AND BY THE WAY: It's a 1988 s-15 BlaZer/JiMMy.. (If you need to add more information to a previous post, please use the edit button. -a_tack) |
RE: Well Got iT
are the bolts stuck? or can you just not figure out how to get them out? if they are stuck try to soak them with some penetrating oil or WD-40 and let them sit for a bit... then try again...
with that body style blazer, you could also try to PM Hanr3... he has done the job on this particular body style... |
RE: Well Got iT
Spray as much penetrating lube in there as you can. Then tighten the bolts, loosen, tighten, etc untill you eventually have them removed. That's what I did.
