Well Got iT
Old Sep 17, 2007 | 06:30 PM
ShaneInsane's Avatar
ShaneInsane is an unknown quantity at this point
Default Well Got iT
Well I have purchased a body lift, and I have tryed to get the Body mounts in the back out, and I am having trouble removing the rear bolts I got the mounts out but I just can't get the bolts out at all.. I was reading on the papaer that came with the body lift and it says somethyng about the bolts are screwd in to the body but I wouldn't see how about going to remove them..
*Combining Consecutive Posts*
OH AND BY THE WAY: It's a 1988 s-15 BlaZer/JiMMy..
(If you need to add more information to a previous post, please use the edit button. -a_tack)
Old Sep 19, 2007 | 11:46 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Well Got iT
are the bolts stuck? or can you just not figure out how to get them out? if they are stuck try to soak them with some penetrating oil or WD-40 and let them sit for a bit... then try again...
with that body style blazer, you could also try to PM Hanr3... he has done the job on this particular body style...
Old Sep 19, 2007 | 05:52 PM
Blazin_Jason's Avatar
Spray as much penetrating lube in there as you can. Then tighten the bolts, loosen, tighten, etc untill you eventually have them removed. That's what I did.
bobby099
Mar 20, 2012 07:13 PM
Silver00LT
Sep 15, 2011 06:01 PM
Buschkj24
Dec 23, 2009 07:00 PM
bman416
Oct 28, 2009 03:31 PM
ivannj
Nov 28, 2005 09:43 PM
