What should I do?
Old Jun 10, 2013 | 06:30 PM
nbguide's Avatar
nbguide is on a distinguished road
Default What should I do?
I want to put 31's on my blazer. Should I just do a Tbar crank and shackles?
Here's the dilemma. I need 4 new shocks and upper balljoints anyhow. I know the RC 2.5" kit comes with all these.
OR
should I do the tbar and shackles and put the BEST available shocks available on my blazer..and of course add some springs. If this is the way to go what shocks should I use and what springs.
Thanks for the help in advance.
Old Jun 14, 2013 | 09:37 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
I did t-bar crank, and lift shackles. Already replaced ball joints with Moog but I also did the ball joint flip. Placing the ball joint on the bottom of the upper A-arm. For better angle. Add that with 4 Rancho rs9000xl adjustable shocks, cost me $250 after mail in rebate on Amazon. I believe the only thing the the RC lift has over T-bar and shackles is the front diff drop brackets to help maintain better cv-joint angles. Hopefully someone who has the RC2.5 on will come in and comment.
Old Jun 15, 2013 | 06:22 AM
nbguide's Avatar
Thanks for the reply K. I ordered the 9000's and they should be here tuesday. Thanks again for your input.
Old Jun 15, 2013 | 08:30 AM
Karcinagin's Avatar
FYI for them to fit the in the front the instruction say to to install it upside down. I had the boot on also but the shock boot was rubbing on the cv-joint boot. So I cut it off, the rear fit just fine.
trobbins
Jan 9, 2013 10:17 AM
blazerrider101
Engine & Internal
Nov 30, 2005 08:31 PM
2001blazer
Nov 7, 2005 11:56 PM
yzf125
Sep 16, 2005 07:20 PM
jeff505
Tires and Wheels
Sep 12, 2005 07:03 PM
