Wierd Question??
Old Mar 19, 2008 | 09:23 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Wierd Question??
I am plannin on gettin 2" shackles but i dont like the idea of crankin the t-bars. Would it be possible to buy a 2" suspension lift for the front, an put shackles in the back? Stupid Question, just curious? Kinda tryin to skimp on cash.
Old Mar 19, 2008 | 09:25 PM
WolfPack's Avatar
Default RE: Wierd Question??
Couple problems with your logic:
A 2' lift for the front is always going to use the t-bars. That's the only front suspension you've got (lets not mention the shock-assist). A 2' suspension lift gives you new t-bar keys and lifts up the front, then comes with all sorts of other goodies to decrease strain on the rest of the front end components. Then the kit includes shackles for the 2' rear lift.
Only way to get 2' without cranking the t-bars is a body lift.
Old Mar 19, 2008 | 09:29 PM
OK, i guess i was lookin at body lifts at first but realized how tough they were to put in. I dont know what to do. I see so many blazers around town, i would like to make mine a bit dif. any suggestions on the cheapest way to get lift?
Old Mar 19, 2008 | 11:10 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
body lifts are easy to install, just very very time consuming..
Old Mar 20, 2008 | 05:22 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
cheapest is shackle and tbar crank...
Old Mar 20, 2008 | 09:53 PM
WolfPack's Avatar
Yea....
Old Mar 20, 2008 | 09:56 PM
Sorry for the stupid question.
Old Mar 21, 2008 | 11:06 AM
WolfPack's Avatar
no stupid questions sir.
Old Mar 21, 2008 | 06:07 PM
I just want to get an all around bigger tire, ill be putting shackles on it, an would like to fill in the space i get with a more beefier tire. I guess i would like to stick with the same rims but if i have to get ones then i will. Any help?
Old Mar 21, 2008 | 06:51 PM
bigger tires on stock rims = rub, you should get offset rims.
edit: also, no lift is going to be cheap, skimping on a cash isnt really an option if you want to do things right the first time.
