Would 93 yj Jeep axles fit?
Just doing some research, and was wondering if the YJ straight axles would work on the 2nd gen S10 Blazer platform? My only concerns are the push button, and if it will line up where my tansfer case is at currently. I haven't committed to a SAS but for $400 for both axles I figured it was worth a shot to ask around for more info. Thanks!
I mean, any axle would work with enough fabrication.
As far as the push button, I don't know enough about the CAD on those jeeps to be able to answer.
As long as the front is driver side drop, it should line up with the tcase, probably have to modify the driveshaft though
Check out Blaz' build thread. He did a great job writing up his SAS build on his Blazer using a Dana 30 from a Jeep YJ.
