ZR-2 Suspension
Hey guys, I've got a 96' GMC Jimmy 4 door 4WD. I'm looking to lift it a little more than it is currently. It's got a t-bar crank up front and a 3in shackle at the rear. Is it possible to put the suspension from an S-10 or Blazer Zr-2 on it? What are the differences between the regular suspension vs. the ZR-2?
Thanks |
It is possible. It's going to be a hell of a lot more expensive and involved then just throwing a simple 2" body lift on it though. It will give you the same amount of lift as a ZR2 suspension for $150-$200, and it can be done in a day.
The ZR2 got its lift from mounting the suspension lower on the frame rails.
^ding ding ding^ we gave a winner!!! Neo is correct. Part the reason why you can not use a lift kit for a ZR2 on a non ZR2 blazer/s10
Originally Posted by neo71665
(Post 321086)
Absolutly not. Just about all of the suspension components are diffrent.
I'm pretty sure you can swap the torsion bars out. I know the rear springs are compatible.
Originally Posted by Red 96'
(Post 321098)
(Post 321086)
if you already have 3" shackles with the t-bar crank, you can either add the 2" BL like Sisk said, or play with the big dogs, and get yourself a 5 or 6 inch SL. 'cause right now, you're almost max'd out. |
I'd say just go with the body lift
Alright, thanks guys. I'm still thinking about replacing the t-bars, they've got just under 200,000 miles on 'em and are probably on the weaker side. I don't know how the leaf springs are supposed to sit, but with the shackle, they are almost straight.
| All times are GMT -5. The time now is 07:46 AM. |
