00 ZR2 no ground to starter relay
Old May 10, 2012 | 09:28 PM
unior's Avatar
unior is an unknown quantity at this point
Default 00 ZR2 no ground to starter relay
00 ZR2 blazer. It won't crank or stay running without a jumper wire in place from pin 85 of the starter relay (coil ground) to battery negative.
I can get the truck started by jumping the relay to ground and then having my helper turn the key to "start"...it will start....run....and then die as soon as i remove the jumper ground wire.
I am confused pin 85 gets good continuity to ground with the key "off" but i lose the ground as soon as the key switches on.
One question of mine....is pin 85 supposed to be a switched ground? If so what switches it...the bcm? pcm?
Also why did the truck shut off when my jumper wire was removed?
Old May 10, 2012 | 09:43 PM
unior's Avatar
Ok was just thinking some more. The fuel pump is also not running for 2-3 seconds after turning the key to "on" position. From the few wiring diagrams I have it seems "G102" may be my culprit. It seems to ground a few items including the fuel pump relay and starter relay.....my question is where is g102? lol
Old May 10, 2012 | 10:23 PM
unior's Avatar
By pin 85 I meant pin 86
eljorgin
May 21, 2019 10:04 PM
cide
May 1, 2009 01:07 PM
Bodar
Jan 25, 2009 01:44 PM
Angel Blazer
Dec 30, 2008 04:11 PM
bestes
May 31, 2008 03:16 PM
