02 Blazer - Brake Light & Hazzards not working
Old Jan 28, 2012 | 12:26 PM
drewilson04's Avatar
drewilson04 is on a distinguished road
Default 02 Blazer - Brake Light & Hazzards not working
I already checked the Fusem], Bulbs & installed a new "brake light switch" but still no brake light or hazzards. I read something about a link between the problem and a "multifunction switch" but couldn't find any details.
I am going to attempt to check the wiring before I take it to a mechanic Monday.
Old Jan 28, 2012 | 12:27 PM
xgiovannix12's Avatar
play with the hazard switch push it or pull it slightly and see if your lights work again
they tend to short out sometimes
Broken Hazard Switch Repair How-to - Car Forums and Automotive Chat
Old Feb 17, 2012 | 08:00 PM
jarrod's Avatar
jarrod is an unknown quantity at this point
my 92 blazer tail lights and signal lights work , but hazzards and brake lights do not. bulbs and fuses are good. can anyone tell me what to check know? they quit working after i had trailer hooked up. thanks
Old Feb 17, 2012 | 08:55 PM
Anubis8472's Avatar
Anubis8472 is on a distinguished road
Does your third brake light work?
Usually when the mutifunction switch goes you can press the hazzard button to the side and they'll work, untill you let go.
Check with a dealership, I don't recall the specifics, but if the problem is that multifunction switch you should be able to get them to replace it under recall (does not matter if original owner).
The switch is the component that the hazzard button is on. Inside the collumn, you need to pull the steering wheel to replace.
Look for the recall info online and take it to the dealer.
Shouldn't cost you a penny.
Used 2002 Chevrolet Blazer Recalls - 2002 Chevy Blazer Recall Reports - Motor Trend Magazine
Old Feb 20, 2012 | 01:39 PM
NeedANewCar's Avatar
NeedANewCar is on a distinguished road
Default Multifunction switch
I just had this problem. I diag the car for 2 days. And found the multifunction switch was bad. 150 bucks and a couple hors of install time and everything was fixed. I have a known good used multifunction switch. if you diag yours and thats the problem id sell it to you for a resonable price.
Old Feb 20, 2012 | 01:40 PM
how much i need one ?
is it the oem one ?
Old Feb 23, 2012 | 07:27 AM
browndog77's Avatar
browndog77 is an unknown quantity at this point
Default Easy temp fix
I developed the same problem w/ my '97 Blazer, and I found that a small shim inserted on the right side of the hazard switch works. I used the plastic retainer key from an electrical connector for romex cable. It has ridges on the sides so it should stay put.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
Nazdreg
Aug 19, 2009 09:53 PM
carlo
Jan 11, 2009 02:00 PM
blackknight
Dec 26, 2006 12:01 PM
