1995 Blazer - Cranks, No spark
Old May 24, 2014 | 01:20 PM
folkenson's Avatar
folkenson is on a distinguished road
Default 1995 Blazer - Cranks, No spark
Help!
1995 Blazer 4.3, Kid's car, died while driving home. New fuel pump. No spark.
Replaced...
Crank sensor
Coil
ICM
Still cranks, no spark at the coil. I have fuel pressure. I followed the test procedure here, still nothing. Part 2 -GM Misfire, No Spark/No Start Tests (4.3L, 5.0L, 5.7L).
PCM???? It's $30 at the junk yard so not a bad option but I'm stumped.
Old May 24, 2014 | 09:13 PM
abig84's Avatar
Distributor issue? Have you taken off the distributor cap yet? See if the rotor is still intached or if it looks good. Also crank the engine with the cap off just to make sure it still spins, that way you'll know if your timing chain broke or not
Old May 25, 2014 | 12:06 PM
folkenson's Avatar
Cap has wires on the side (not round) is it still a mechanical rotor under there?
Old May 28, 2014 | 08:45 AM
folkenson's Avatar
Distributor looks good. Thinking I might throw a $30 PCM from the junkyard at the problem??
Old May 29, 2014 | 09:57 AM
folkenson's Avatar
New PCM and I now have spark and a short run up occasionally while cranking or with starter fluid. I can keep it running with starter fluid. It's almost like something is being shut down once it fires.
HELP!
Old May 29, 2014 | 01:06 PM
abig84's Avatar
is there any kind of theft light on? saying security or anything like that? another stupid thing you can try is if you have another set of keys, try using one of them to see if it will start. if youre in a quiet area listen for the fuel pump to prime while tyou turn the key on. might have to have someone lay under the truck to listen but it should buzz for 3 seconds. you can try tapping the tank with a hammer if it doesnt make noise.
but for both to go out at the same time that usually a crankshaft position sensor or other issue.
Old May 29, 2014 | 04:29 PM
folkenson's Avatar
Nothing since that one quick run up. Re-did the test procedure for the coil, ICM, PCM etc using my meter and LED test lead. Swapped all new parts with old parts. There is no switching signal getting to the ICM or coil. Swapped ICM with old one. Found remnants of old auto start unit. verified not cut or shorted wires. clipped old wires that were tapped into the OEM wires to make sure there isn't a short to ground etc.
New fuel pump last fall, have fuel pressure and pump sound.
Still nothing
kwbond
Mar 18, 2014 12:39 AM
abe_f
Apr 1, 2013 11:19 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
blaze1925
Aug 3, 2005 11:45 PM
