1997 Blazer 4wd electrical issue
I started my Blazer last night and discovered the instrument cluster lights, tail lights and 4wd did not work. Fuses are good. Has anyone experienced this? How did you resolve it? TIA.
Yep, I have checked all fuses, twice. Also the 2 relays in the fuse box. I was hoping there was a common junction, ground, troublesome connector that I was unaware of.
Another question though, what are the 3 relays in the glove box for?
The grounds are common to most of the functions in the front half of the truck and the tail lights are on separate grounds.
Check for voltage into the illum fuse 23 which comes from the dimmer in the dash. If no voltage then the dimmer has failed.
Since you have checked all the fuses, go to the tail lights and find out if you have lost power or ground to the lamps.
George
George
If 4wd also does not engage that may be a separate issue
George
95Blzr
Sep 28, 2008 02:09 PM
