1997 Blazer 4wd electrical issue
Old Nov 13, 2021 | 09:46 AM
WilAndersen's Avatar
WilAndersen is on a distinguished road
Default 1997 Blazer 4wd electrical issue
I started my Blazer last night and discovered the instrument cluster lights, tail lights and 4wd did not work. Fuses are good. Has anyone experienced this? How did you resolve it? TIA.
Old Nov 13, 2021 | 03:47 PM
GeorgeLG's Avatar
In what way did 4wd fail. No lights, flashing lights and no transfer case activity, transfer case activity and improper engagement?
are you sure that all three items failed simultaneously?
George
Old Nov 13, 2021 | 07:26 PM
The 4wd and instrument lights failed simultaneously, I'm assuming the tail lights did as well. Absolutely nothing on the 4wd, no lights on switches, no relay clicking, nothing.
Old Nov 13, 2021 | 09:34 PM
GeorgeLG's Avatar
Check the following fuses:
pk pls fuse 3, ipfb
4wd fuse 19, ipfb
gauges fuse 4, ipfb
turn b/u fuse 26, ipfb
George
Old Nov 13, 2021 | 11:03 PM
Yep, I have checked all fuses, twice. Also the 2 relays in the fuse box. I was hoping there was a common junction, ground, troublesome connector that I was unaware of.
Another question though, what are the 3 relays in the glove box for?
Old Nov 14, 2021 | 12:26 AM
venom4ever4em's Avatar
venom4ever4em is on a distinguished road
Your headlight switch/interior light switch has failed. Happened to me also, no lights, replaced switch with a good one from the junkyard and all lights work.
Old Nov 14, 2021 | 08:04 AM
GeorgeLG's Avatar
The grounds are common to most of the functions in the front half of the truck and the tail lights are on separate grounds.
Check for voltage into the illum fuse 23 which comes from the dimmer in the dash. If no voltage then the dimmer has failed.
Since you have checked all the fuses, go to the tail lights and find out if you have lost power or ground to the lamps.
George
Old Nov 14, 2021 | 10:41 AM
GeorgeLG's Avatar
Or you can just go for the switch since that is a high likelihood. I like to verify first so I don’t waste my time and money but some prefer to replace the most likely part straight away. Dealers choice.
If 4wd also does not engage that may be a separate issue
George
KP70
Apr 2, 2015 03:35 PM
dreadinger
Jan 27, 2011 01:46 PM
Impact
Feb 2, 2010 12:01 PM
nnnon632
Sep 30, 2009 07:34 PM
95Blzr
Sep 28, 2008 02:09 PM
