1997 blazer wiring harness
Old Mar 11, 2026 | 09:13 PM
tin's Avatar
tin
tin is on a distinguished road
Default 1997 blazer wiring harness
I am trying to get the harness out of my blazer and at the back of the engine near the distributor and it goes down and splits off into the left and right. I can not find where they lead to.
Old Mar 12, 2026 | 05:56 AM
The part that runs down the driver side (left side) will run down to the transmission, both of the bank 1 O2 sensors, as well as the transfer case with related switches/sensors (if 4wd), and vehicle speed sensor. The passenger side should have a ground on the back of the passenger side cylinder head and run down to the Bank 2 O2 sensors it may also have some of the sensors on the back of the engine (oil pressure sending unit or switch depending on how the truck is equipped, knock sensor, etc.). I say should have a ground on the back of the cylinder head because you can tell if someone has been there before by whether they put that one back in place. It can be a REAL PAIN to reinstall.
Evgeniy Kuzmenko
Jul 3, 2022 12:16 PM
granitebayde
Jul 8, 2012 11:28 AM
joeshannallie
Nov 27, 2010 04:15 PM
mikeknuckey
Feb 5, 2010 08:25 PM
cain_45
Nov 5, 2007 07:43 PM
