1997 Blazer won't turn over
Old Apr 18, 2012 | 11:23 PM
derbyman8723's Avatar
derbyman8723 is on a distinguished road
Default 1997 Blazer won't turn over
I have a 1997 blazer and when I try to crank it over there is a clicking sound at the relay box. The battery is charged. I was wondering if anyone could help I'd really appreciate it. Also if anyone knows what two wires goes into fuse block for the crank fuse... Thanks
Old Apr 22, 2012 | 10:59 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Is your starter cylinoid clicking,I would check that.Either you have bad connection somehwere usualy where the wires go onto the starter or its bad.
Old Apr 22, 2012 | 06:20 PM
When I go to start it the only thing it's doing is clicking at the relay. It's not getting to the starter or anything. I got the dash out n traced all wires. I don't no if this sounds right but it clicks at the relay n seems like after the relay it doesn't go any further. I just don't know man.
Old Apr 22, 2012 | 10:43 PM
xgiovannix12's Avatar
is the battery full charged ? have you cleaned the battery terminals ?
try hooking a charger and see if she trys to turn over
Old Apr 23, 2012 | 11:08 AM
Yea terminals are clean and I've had a charger on it when I've been working on it.
Old Apr 25, 2012 | 04:12 AM
Something else I realized and not sure if this is right... When I turn the key to start position the back up lights come on.
Old Apr 25, 2012 | 04:34 AM
tripovermyego's Avatar
tripovermyego is on a distinguished road
Sounds like you have a wiring issue. So it just clicks at the relay and the reverse lights come on? Make sure youre all the way in park. Try turning the switch on and put it in reverse and check to see if your reverse lights come on like they are supposed to. Then make sure its in park all the way.
Old Apr 25, 2012 | 06:42 PM
Yep just clicks at the relay. There's a purple wire that makes the reverse lights come on. I'm not sure were this wire is suppose to go tho.
Old Apr 25, 2012 | 06:47 PM
pettyfog's Avatar
Try starting it in neutral.. pushing lever up toward reverse.
Old Apr 26, 2012 | 12:43 PM
I see where pettyfrog is coming from hes suspecting a bad nuetral safety switch.
Im just wondering have tried replacing the relays and check all your fuses underneight the dash and if theres a fuse box under the hood I would check all those.I would also trace your ground wire from the batter to the frame and make sure its getting a good connection.Man I hate wiring and electrical problems.Im going through a major wiring issue on my Jimmy also.
