2000 Blazer 4,3 vortech ground wire
4 Attachment(s)
Hello Blazer brothers!
Long time ago I take engine apart and send cilynderheads to shop. Now I am putting engine back together and I dont remember under what bolts where the ground wire (located between engine and fire wall) . one side should be attached to cilinderhead (left or right? or there should be 2 wires?) and ohter side must be attached .... ? intake or blazer body? I hope easy question for you guys, I am out of ideas ... I want to do it right. Thank you for help! Veiko |
on my blazer, the 1st pic bolts down low on passenger side cylinder head (tight spot) the other end goes up high on firewall. Pic 2 on my blazer there were 2 more grounds put together that bolt to drivers side cylinder( closer to intake manifold) also a tight spot because of fuel lines.
Job done thank you!
