2000 Blazer 4,3 vortech ground wire
Old Feb 17, 2015 | 09:48 PM
weix2's Avatar
weix2 is on a distinguished road
Default 2000 Blazer 4,3 vortech ground wire
Hello Blazer brothers!
Long time ago I take engine apart and send cilynderheads to shop. Now I am putting engine back together and I dont remember under what bolts where the ground wire (located between engine and fire wall) . one side should be attached to cilinderhead (left or right? or there should be 2 wires?) and ohter side must be attached .... ? intake or blazer body?
I hope easy question for you guys, I am out of ideas ... I want to do it right.
Thank you for help!
Veiko
Attached Thumbnails 2000 Blazer 4,3 vortech ground wire-22.jpg   2000 Blazer 4,3 vortech ground wire-11.jpg
Old Feb 19, 2015 | 03:45 PM
bluebird's Avatar
bluebird is on a distinguished road
on my blazer, the 1st pic bolts down low on passenger side cylinder head (tight spot) the other end goes up high on firewall. Pic 2 on my blazer there were 2 more grounds put together that bolt to drivers side cylinder( closer to intake manifold) also a tight spot because of fuel lines.
Old May 17, 2015 | 04:29 PM
weix2's Avatar
Job done thank you!
eljorgin
May 21, 2019 10:04 PM
Dug44
Nov 29, 2012 06:24 AM
Dan Krebs
Sep 5, 2012 06:51 PM
airwolf9090
Sep 27, 2011 06:31 PM
cide
May 1, 2009 01:07 PM
