2001 Bravada Fog Light Replacement Question
So my passenger side fog light broke on my Bravada and I was given an Amazon giftcard for Christmas at work. I checked and they don't show any for a Bravada, but I found one for a 2001 Blazer. Are they interchangeably? These are the fog lights that are mounted in the bumper. I looked for a part number but was unable to find one online and thought I'd check here.
Thanks!
Thanks!
They are either 880 or 881 for the bulbs, but I will have to do some digging to find the housing part number.
The difference between the two is the 880 has the connector straight out the back while the 881 has the connector turned 90° to the bulb body.
I think that either work and that my old 2000 Bravada had 880's.
*Edit* I think the ones on this catalog page from LMTruck.com shows them and they look to be the same as those that came in the Blazer/S10 when mounted in the bumper. The most common fog light option on the Blazer/S10 was in the turn signal housing which would not work in your case.
bigtone23
Mar 27, 2014 11:11 PM
shortandlong
Oct 3, 2008 07:29 AM
