3rd Brake Light Problem
Old Nov 9, 2011 | 08:05 PM
justoblaze11's Avatar
justoblaze11 is on a distinguished road
Default 3rd Brake Light Problem
What if you are not getting power to the third brake light in a 1996 blazer?
Old Dec 6, 2011 | 12:40 PM
BNAzer's Avatar
BNAzer is on a distinguished road
Default Third brake light inop
98 Blazer:
Similar question about the under hood fuse box. The owners manual shows a "VECHMSL - Vehicle Center High-Mount Stop Lamp" on 6-60 & 6-61. The fuse position is in the lower right corner of the fuse box. It looks like "a big one" but the amps aren't listed. There isn't a fuse in this slot in my box.
Is this the same "third brake light" we're talking about with its own fuse, since its an LED... or a different optional animal.
I need to invest in an ohm meter as well to see if power is at least getting to the connection.
I got 2 LED third brake lights for a whopping $4 yesterday at the local pull-apart. Neither one worked when hooked up. Will try them on a 12 volt batt later this week...
BTW, taking the aft header apart by the aft courtesy light is simple.. a steady but gentle tug on the plastic from one end working your way toward center will release the underside retaining clips. No big deal.
When its off you can finger fish through the dome light hole or frame area to grab the 2 wires coming from the LED strip. Undo the the electrical clip and check the amps for power.
BNAzer
Old Dec 11, 2011 | 09:15 AM
Rbfoster67's Avatar
Rbfoster67 is on a distinguished road
How about a 2000 blazer. Same problem. Fuse for vechmsl is a 10a and it is where it should be and looks good. I've changed light, checked wiring and still nothing. What next?
Old Dec 11, 2011 | 10:55 AM
pettyfog's Avatar
weight down the pedal
Trailer wiring? Check the light blue wire. If it works, it's on different fuse. So go back to the vechmsl fuse and test for voltage both sides.
Note that Cruise 'disengage on brake' also uses this fuse
Volt both sides, check for volt going into housing. Note it is also light blue wire.
If volt on light blue going in and light doesnt work check OTHER wire. If volt reads on it, bad ground
If no volt anywhere above, Crawl under dash and note 2 white wire from brake switch, one of them has come loose.. OR..
Go to Underhood FB look for light gray connectors, wiggle test wires while helper watches
Wire from Bl SW is C1 D11
Old Dec 11, 2011 | 11:02 AM
rriddle3's Avatar
*Moved these posts into a thread of their own.*
dano440
May 11, 2012 06:57 PM
steveshane67
Jan 28, 2010 05:06 PM
drperry
Aug 16, 2009 05:24 PM
kiwiblazer
Sep 9, 2008 01:48 AM
magnum434
Sep 30, 2006 02:03 PM
