4 wheel drive switch indicates its stuck in 4 HI
Old Sep 1, 2011 | 11:56 AM
HigherPower's Avatar
HigherPower is an unknown quantity at this point
Default 4 wheel drive switch indicates its stuck in 4 HI
4 wheel drive switch indicates its stuck in 4 HI, got sounds in the dash and underneath like its trying to shift, 4HI to 4LO and return works just fine. I was sponging around looking for an answer and didn't find anything except lost of cant get into 4x4, if anyone has an idea on what to check or do I would appreciate it
Old Sep 1, 2011 | 12:20 PM
NV233 No Mode Switch (ie. 2HI to 4HI) gives you some things to check. You'd need to compare the wiring diagrams to make the necessary adjustments to the procedure that was created for the 2nd gens in terms of the connector terminal references.
Old Sep 7, 2011 | 06:31 AM
False alarm... I rolled it out of the garage and it disengaged!
Old Sep 7, 2011 | 07:04 AM
It often requires a little bit of movement on the part of the vehicle to change modes/ranges. The move from 4HI to 2HI should be "easier" than the move from 4HI to 4LO, but these wonderful encoder motors do have their quirks.
Old Sep 7, 2011 | 08:16 AM
Funny thing is I don't remember ever engaging the 4wheel drive before the battery was disconnected for a few weeks while working on it. Then when connecting it back up it was, or at least indicated it was in 4HI... so yes id aggree it has something in it... (note to self no water or food after midnight....)
Old Sep 7, 2011 | 08:25 AM
The early electronic 4wd setups could sometimes be flakey after a battery disconnect/reconnect.
Old Sep 7, 2011 | 08:37 AM
Well any way thanks for the help alleast now I have a plethera of information on the 4wheel drive components and learned something about it in the process! Hopefully I will have it on the road this week to give it a test run and post some pics.
mirrorimij
Jun 8, 2019 03:34 PM
Ugly_Monkey
Feb 21, 2015 10:56 PM
matt92
May 1, 2011 04:39 PM
RCars2
Aug 4, 2007 11:29 PM
dcblazer
Dec 18, 2006 06:07 AM
