4l60e problem under 10° celcius
Old Apr 14, 2014 | 01:03 PM
pascal.19's Avatar
pascal.19 is on a distinguished road
Default 4l60e problem under 10° celcius
Hello !
i'm a french owner of 1997 blazer, i have a strange problem with my 4L60E.
My tranny shift bad Under 10°celcius, at cold start, this one stay in third. I pluggued an obd2 scantool and this display lot of solénoïdes problems...But there are good, because my tranny works fine after a fiew hours on parking.
When the problem happens, it's impossible to remove the ingnition key.
I think that the problem is the wire harness of the ingnition switch.
Someone has solved this problem is the past ?
Thank you in advance for your reply and i'm very sorry formy bad English.
Best regards
Old Apr 15, 2014 | 12:31 PM
pascal.19's Avatar
Hi !
Nobody has an idea ?
Old Apr 15, 2014 | 06:02 PM
cubawashere's Avatar
cubawashere is on a distinguished road
Yes I believe you are right. Here is a PDF is reference to a similar defect.
http://www.atra.com/bulletins/2009/mar/atb1244.pdf
There are few people who know anything about or how to diagnose transmissions and can usually only be diagnosed in person. So the lack of the response is not surprising
Good luck, and post an update if it fixes it!
Old Apr 16, 2014 | 04:07 AM
pascal.19's Avatar
Thumbs up
Hi ! Thank you for the "PDF", i will place a post when this problem is fixed.
regards
Old May 9, 2014 | 11:33 AM
pascal.19's Avatar
Default shifting problem fixed
Hi !
I has replaced the ignition switch and now my tranny works very fine.
A big thanks from France.
Thank you very much for the PDF.
Old May 9, 2014 | 09:19 PM
Yay!! I'm so glad to here! Many more years of driving! Cheers!
Old May 10, 2014 | 01:37 AM
97blazetitsup's Avatar
97blazetitsup is on a distinguished road
classic ignition switch symptom
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
dksob81
Jan 30, 2009 06:33 AM
doubleuap
Nov 10, 2008 12:34 PM
95blazer8620
Oct 19, 2007 01:26 PM
